driver rear ABS wire break
Old 01-15-2013, 07:17 PM
myrunner26's Avatar
Question driver rear ABS wire break
Only had a grass driveway which turned to mud after the past two days of rain. jackstands failed and one bent the crap out of the driver rear break-line as wekk as broke the ABS wire... is there any way to repair the wire? if not does anyone know a viable route to go with fixing it but not costing a butt load
Old 01-16-2013, 12:42 AM
KZN185W's Avatar
Are you referring to the wire from the speed sensor in the rear axle? it'sbest to replace them to ensure that they're working ok as these are safety features. part numbers are 89545-35030 (RH) and 89546-35030 (LH).
Old 01-16-2013, 10:07 AM
tripz's Avatar
the rigid brake line should def be replaced and an easy swap, just have the right wrenches (10 mm) so you dont round the fittings when loosening them, pb blaster for a few hrs should help too
Old 01-17-2013, 08:42 AM
So Many Roads's Avatar
Replace the ABS lines with OEM ones in great shape:
https://www.yotatech.com/forums/f109...-parts-261594/
PM me if you are interested.
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
lledwod
08-30-2016 01:03 PM
icentropy
07-11-2015 07:21 AM
toyota32
07-06-2015 05:42 PM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: driver rear ABS wire break
