Driver Footwell Click
Old 08-30-2008, 08:01 PM
MunkeyTX's Avatar
Howdy guys,
Recently, I've noticed a clicking noise coming from the drivers footwell, specifically right behind the clutch/far left footrest area. It sounds exactly like a relay clicking, and it happens when I use the clutch, sometimes over bumps, and if I get on or let off the gas pedal quickly; I'm thinking its happening when the body slightly flexes on the frame, maybe a broken spot weld??
Not really a immediate problem, but it is kinda annoying.
Just wondering if this has come up with a simple fix before.
Thanks!
Old 08-30-2008, 08:52 PM
BigBallsMcFalls's Avatar
blinker fluid is low
Old 08-30-2008, 08:54 PM
MunkeyTX's Avatar
Intelligent Donkey You Are!
Mmm, crap, I forgot about that! Guess I should check the muffler bearings too??
Old 08-30-2008, 09:04 PM
Godzilla's Avatar
These members report a squeaking, however it may be related.
https://www.yotatech.com/forums/f2/f...bushing-19137/
Old 08-30-2008, 09:06 PM
Godzilla's Avatar
Here ya go,..most likely the bushings or the spring
https://www.yotatech.com/forums/f2/9...eaking-134929/
Old 08-31-2008, 12:52 AM
scuba's Avatar
x2 on the blinker fluid, i would check that first
Old 01-14-2009, 10:37 PM
idanity's Avatar
i would check the welds and the master cylinder shaft..
this is mine 2 days ago.
hope that helps
happy trails
bvleonov
08-22-2015 11:39 PM
94yotaky
07-23-2015 07:50 AM
coryc85
07-06-2015 04:07 AM
Quick Reply: Driver Footwell Click
