Drive Shaft Sounds Like Death *Videos*
Old 02-07-2012, 03:36 PM
TFJ-4runner's Avatar
First let me say that I have almost zero drive shaft experience so far. I know the tell tell sign the U-joint is bad when you apply throttle and get a thud when you let off. I dont seem to be getting that, but I do believe I have an issue where braking to a stop the rear end settles with a slight thud. It stopped after the lift went on. Apparently it's common but I doubt its something to not worry about.
I'm reading that my zerks may need more grease. I was able to get the majority but the hose broke before my buddy had to leave. So I don't think the slip yoke has any grease. If that's not it then the U-joints must be the problem? Everything seems tight when rotating it. Up and down It hardly moves as well.
I have put roughly 8,000 miles on this since I bought it and no clue about this particular upkeep with the previous owners. I've been trying to figure this noise out for about a month now and it is now worse to where I can. So here's two videos the first has acceleration and the other is idle speed. I want to get it fixed before Saturday when the 35's go on. Let me know what you think ,thanks guys...
2000 4runner 4x4 W/ E-Locker 8 wraps in the rear and 2" BL approximately 160K miles
These are the links I found in reference to this issue.
4Runner Possible Slip Yoke Binding. - YotaTech Forums
4-Runner thump on stopping - YotaTech Forums
[YOUTUBE]http://www.youtube.com/watch?v=NejCUn8N5zk[/YOUTUBE]
[YOUTUBE]http://www.youtube.com/watch?v=x7yom3ahXuE[/YOUTUBE]
Old 02-07-2012, 03:53 PM
bjlambert's Avatar
I had to change my driveshaft for the 4WD in my 94 pickup, IFS. It was making the same sound when I'd engage 4WD, like a clunk clunk clunk and scrunching every so often. Are you experiencing any of this? Or is it only when you slow down and speed up? I'd definately suggest changing both U-joints, as it sounds like something is knocking something fierce. Also, if you have any vibration at any speed, your driveshaft may have lost a weight and needs to be rebalanced. The U-joints can be hell if you don't have a lot of experience, just to let you know. Be sure to have someone nearby or at least a walkthrough if you attempt. Good luck!
Old 02-07-2012, 04:00 PM
Nothing with the front with the drive shaft or cv's. It only happens when the rear drive shaft is spinning. Its the worst when accelerating lightly. A wot I almost goes away which I think it due to g force keeping it planted. Not sure though just a theory. There's vibration which I thought were factory tires but there's no way now. I'll be letting some one else handle this one I just need to know what the heck is going on. It sounds like the clunk is coming from the center of the drive shaft.
Old 02-07-2012, 04:05 PM
bjlambert's Avatar
Does it have a steady bearing splitting the driveshaft? If so, the bearing could be messed up.
Old 02-07-2012, 04:13 PM
I believe it does. Do you know the best way to tell if that's what it is? I feel just the slightest movement when moving the shaft up and down.
Old 02-07-2012, 04:53 PM
Lycanistic's Avatar
Possibility of spline wear on the slip-yoke, have seen this before too. Does the amount of vibration seem to vary with speed like it comes and goes at particular speeds. Give kinda a resonance to it at say 55, but a gentle humm at say 65-70?
Old 02-07-2012, 05:42 PM
Yes, the noise is way louder based on the load and the speed. I feel vibrations around 60-70 and it varies from there. What all is involved with spline wear?
Eggslinger
06-08-2019 03:32 PM
A2theK
01-10-2016 10:18 AM
Iceman4193
07-15-2015 04:48 PM
andrewtexas123
07-14-2015 04:29 AM
mlavery85
07-12-2015 10:33 AM
Quick Reply: Drive Shaft Sounds Like Death *Videos*
