Drive shaft questions (broken cardan joint?)
cant find anyone online that carried the centering bearing. can anyone help? do normal shops carry these, or are they a specific item that ill have to get from the stealership?
(bearing that is damaged) (center of cardan joint)
this is what the bearing sits on.
So what exactly happened??
You can get 25% off with free shipping from Northridge Toyota.
Read the first post and go from there... https://www.yotatech.com/forums/showthread.php?t=72371
not sure what happened, i was driving from louisiana, to central alaska, and about 3/4 of the way through the trip my truck started to shake, and pop from the drive shaft while moving, figured it was a ujoint, but they were fine
https://www.1sttoyotaparts.com/partscat.html
Or you might find a low mileage one at a bone yard. What truck is it? I have a complete drive shaft from a 2001 Taco ext-cab with only 27,000 miles on it but shipping might get pretty pricey to Alaska.
shipping are by weight not by distance. i know that for sure because i ship through USPS every week.
Try Bob Bridge Toyota for a new one:
http://cgi.ebay.ca/Toyota-Pickup-dri...QQcmdZViewItem
C$69.99 vs. C$250 from the dealer up here in Canada. I ordered one last week and will apparently have it this week.
The local driveshaft place said they could squeeze a new center bearing and rubber into my old casing assuming it was not too beat up, but they wanted $125, so the above link is still a better deal.
This supplier might be especially relevant to Canucks (like me) as the supplier is in Richmond, BC - so no border boondoggles, taxes or brokerage fees.
Ooops - just realized you have a newer truck than mine.
TURBOrunnerNM
07-22-2015 11:01 AM
Avenged
07-09-2015 07:55 AM
Jnkml
07-06-2015 01:20 PM
