Dramatic Mods...
Dramatic Mods...
I'm looking for the most dramatic mods for my truck that are still safe for my 20 year old engine.
1. LCE Headers - Definite.
2. Big Bore Throttle Body - Worth it or not?
3. Camshaft - Any good suggestions for a 22RE?
4. Electric Fan - Worth it or not? Is it loud?
5. Block Brace - Worth it on a 120 HP Engine?
Thanks for any feedback.
wont need a block brace, the fan is a good thing, dont know if its loud.... i personally would get the smallest upgrade cam you can, you dont need to put a huge cam if otehr things arent done and if you upgrade the top end mad, you should do the bottom end as well, if not keep it small up top.. from what i have heard, throttle body spacers dont really do much....
Thanks for the reply. Yeah, the only reason I'm not sure about the electric fan is because I don't know if its loud. The stock fan that runs off a belt is loud at first, been then it cuts off (because of the fan clutch) and runs a constant speed - quietly.
Header and cat back exhaust would be the first thing I would do.
I would chose a cam that gives you more torque at a lower RPM than horspower at a higher RPM.
An electric fan should run quiter than you stock mechanical fan and worth a few HP. I dont consider this a dramatic mod though.
Look into getting some balanced injectors from LC Engineering or others. Not really a dramatic mod either but will make the motor run better and more efficient.
SoCal, he's a 2WD'er. He's got nice small wheels and tires, so torque probably isn't as much of an issue.
Upgrade your pipes but make sure to stick a muffler on... Friend has a truck just like yours with no muffler and its one of the riciest things I've ever heard. Electric fans can be a very good thing. They usually only come on when the engine temp. warrants it.
i had just a cat on my truck for awhile... it sounded good, but got really annoying jsut too loud after awhile... a neighbor of mine who is actually like my best friend said it woke her up one morning.. oh yeah, and she actually lived 1/4 mile away...
Cherry bomb on mine. It is too loud at times, but dang does it feel good to press it in and get that throaty throwback. It sounds very V6/8ish, but I don't think its a sound that would go with a truck like yours Yotatruck.
Hmmm. I should take a new video of the exhaust sounds...
Originally Posted by epic37311
If your gonna do the cam go ahead and get a valve job to.
yes definately..... if going with a cam, replace the valve springs, deck the head for true, get new headbolts or studs, and get new rocker arms and springs, also get a valve grind done and the valve seals replaced....
check out www.engnbldr.com i have heard great stuff about him
Originally Posted by jimabena74
i have a flowmaster 40 with a turndown right now.. i love it. my old magnaflow sounded better though... i also have an intake mod though that an efi truck cant do.....
Originally Posted by Plays_with_Toys
WOOHOO for the airfilter mod! I'm gonna try and go two inches taller on my next one.
my air filter is huge... but i also have a 3" bodylift.... i got the idea from you i had a filter when i was making it that was 2x the stock size... and i had to actually lengthen the stud from that to clear the new huger air filter http://www.explorerforum.com/data/sh...y.php?cat=3367
Ok, so...
2. High Flow Cat - Definite.
3. Flowmaster 40 - Already have it.
4. Electric Fan - Probably. Will the LCE 22R Black Magic Fan work with my 22RE?
5. Camshaft - Maybe alittle further in the future due to $$$.
Thanks for all the feedback. Any more ideas?
Originally Posted by Tacoma750
BTW...Elctric fans can be loud! I ahve one on my 71 chevelle..And i can hear it over my motor...And my exhuast is EXTREMLY LOUD! just a thought lol
That's what I was afraid of. I need a quiet electric fan.
If it were me, I'd get a new head with oversized valves from engnbldr.com, stick his 270 cam in it, Thorley headers (lots less dough than LCE) into 2" exhaust, then step up to 2.25 at the cat. I like Dynaflow mufflers...
Along with that, do the electric fan, maybe find underdriven pulleys at a wrecking yard or something for your accessories.
I'm still trying to figure out what I can do to my intake that's smog legal. At least visually...
I honestly can't imagine the bigger throttle body helping on anything but an extremely modified engine. Our VAF and intake tube is so friggin restrictive that a bigger TB seems an ungodly waste of money. But I've been wrong before...
