Drain plug torques????
Old 03-31-2003, 05:13 AM
billyho's Avatar
I'm a habitual over-tightener!! Does anyone know the correct torque for the draing plugs? Engine oil, tranny, transfer and differential.
This is on a '97 Tacoma, V6, 5SPD, 4WD.
Thanks!!
Old 03-31-2003, 05:18 AM
Erc
Erc's Avatar
Oil drain plug should get 29 foot pounds. Don't know about the other stuff.
Old 03-31-2003, 05:34 AM
Bumpin' Yota's Avatar
Not 129ft lbs? oops!
Old 03-31-2003, 06:28 AM
growinseed's Avatar
On drain lugs I go snug+ a bit. I fractured a finger tip removing the rear diff. from it being over tightened. I use a oil plug gasket with copper on the outside and rubber in the middle. avalible at NAPA. It makes a great seal at lower torques. IMO tight enough so they don't loosen going do the road but are not a PITA when you remove them in the future. Numerically 10 -15 ftlbs. No torques specs. in my FSM for the drain plugs
Nathan
Old 03-31-2003, 06:30 AM
billyho's Avatar
Great, thanks for the help!
Billy
91yotapup
07-27-2015 07:19 AM
kcaudill
07-20-2015 12:06 PM
daddio
07-18-2015 10:20 AM
colasurdo
07-17-2015 08:28 AM
Snort
07-09-2015 03:58 PM
Quick Reply: Drain plug torques????
