drag in 4wd
drag in 4wd
so the other day i went out and when i put my 4runner in 4wd there was some drag on the passenger side and it was pulling to the right. i took it out of 4wd and nothing. what is going on here
no. goin straight down the road engaged in 4 hi it was pulling to the right. Is this an axle problem or something in the hub or what?? im totally lost here
It shouldn't do that, I sometimes pop mine in 4WD on the road (straight line only) just to keep the CVs lubed and it never pulls or drags. I'm at a loss to think of what would cause it. The first thing I'd do is unlock the hubs and crawl under the truck and start tuning the CVs by hand to see if they turn freely and smooth.
Just thought of one thing that would cause that, if one tire is a different size than the others it will cause binding in 4WD.
If the gears in the front diff are a different ratio than the gears in the rear diff there will be a lot of drag in 4WD, but in 2WD it will be fine. Some history of your truck may help.
Yeah, that sucked
Big Little Bear
230
11-13-2023 11:42 AM
kawazx636
10-06-2021 03:03 PM
Cycles
09-29-2015 06:37 AM
