down side to 1 speed Taurus Fan?
Old 02-27-2004, 01:14 PM
Marc's Avatar
I searched and searched but couldn't find any real info on the 1 speed Taurus fan other than every one says GET THE 2 SPEED.
Well, after going through all (30) tauruses at my local bone yard all I could find were the 1 speed kind.
Seeing as how my OEM fan blew up wrecking all kinds of havoc I'm going to throw this $15.00 fan in until I can find the 2 speed.
What's the downside to the 1 speed? Also, it's 5.5" deep. Will it fit? I've already removed the fan clutch.
Old 02-28-2004, 05:03 PM
Marc's Avatar
Ok I got one. It draws 30 amps.
Old 02-28-2004, 06:34 PM
bomberyota's Avatar
The only good one speed I found came out of an SHO Taurus. It's thin and it blows enough air to cool a V-8! I like it my gauge never reads more than 1/4 of the scale and I used to over heat like crazy with my old Flexalite!
Old 02-28-2004, 08:12 PM
Robinhood150's Avatar
Did you get it to fit? My 2 speed, flat motor fan has about 1/8" clearance so your much bigger fan motor will be pretty hard to fit without moving things around.
Isn't 30 amps a lot for the stock alternator?
Old 02-28-2004, 08:32 PM
amusement's Avatar
A stock alternator made after 1984 produces 60 amp's. Early models produce around 40 amp's.
Old 02-28-2004, 08:41 PM
Duffdog's Avatar
ya know--- you could get an AC fan from an 88mr2 with air conditioning, those dual fans fit in front of the radiator without any mods and blow more air than a tore-ass fan while drawing less amps and being quieter. Thats what i have on my truck-- its a toyota part, so im more confident that its not going to die.
T
Old 02-29-2004, 12:35 PM
Marc's Avatar
Yep, you're right, it's to big to fit easily and 30 amps is more than I want it to draw.
I might try and find a MR2 fan if i can't find a 3.8.
mdev126
10-04-2015 04:48 AM
coryc85
09-09-2015 06:24 AM
MTLroadierunner
07-06-2015 12:17 PM
wilbertd
07-06-2015 07:39 AM
zd92655
07-05-2015 04:25 PM
Quick Reply: down side to 1 speed Taurus Fan?
