Door wont open
Old 07-09-2003, 09:55 AM
runnerboy97's Avatar
Door wont open
SO i go to put some crap in the backof the 4runner this morning, and i cant get the door open. I have tugged, pulled, sprayed the handle hinges with lube. but nothing works. I've tryed cycling the locks to see if they are suck, but i can feel it unlock when i use the key. So what should i do now. Is there some way to get the inside panel off to try and get at the latching mechanism. I think something broke because i can hear something moving in the door, but nothing happens. This really sucks. please help
Old 07-09-2003, 10:32 AM
Coop's Avatar
yo, i also have had trouble with the back hatch, the handle just won't pull all the way. usually i just keep locking and unlocking the doors (remote and at the pdl) and usually it will budge.
so last weekend this happened just as i was going out the door camping, i got it open and decided to frig with the latch...big mistake! the latch got stuck in the closed position with the hatch open. i had to unscrew the latch/lock thingy from the door and give the cable a yank. haven't had any probs since!
Old 07-09-2003, 10:37 PM
Erich_870's Avatar
Do you have a tail gate or a big up swinging door thingy Ok, so I'm retarted tonight:pat: Anyway, I have had some trouble with my tail gate torsion bar on my 1st gen getting kinda stuck and I have to reach down and pull it down and it works. If you don't have a tail gate then then I will blame the beer and shut up
Old 07-10-2003, 01:01 PM
After some persistent tugging, pulling hitting and lubing i finnally got the door open, but i know the linkage inside is broken. HOw do i get the interior panel of the back hatch off so i can fix it. anyone have a factory sevice manual or somethin the can get the diagram out of, thanks. its a 1997 4runner by the way.
Old 07-10-2003, 04:36 PM
SO i called the dealership here and talked to a mechanic. He told me how to take apart the rear door, pull the latch mechanism and so forth. I got it all apart and all i said was $h!t. the cable was all corroded so was the little rod going from the latch to the realease, it was all siezed up and stuck, i pulled it all apart cleaned it up and got it working again, but i am still gonna order the new cable, so it wont sieze up in the housing again. I'm glad i got it all worked out
theking11863
03-19-2016 09:36 PM
Leviticus6432
11-20-2015 05:06 PM
bvleonov
08-22-2015 11:39 PM
izzmee
08-17-2015 10:20 AM
britishdudes2dr
07-25-2015 06:47 AM
Quick Reply: Door wont open
