YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 01-02-2005, 08:27 AM   #1 (permalink)
Vato Loco's Avatar
Send a message via AIM to Vato Loco
Does The Weight Of A Grill Guard Reduce Tread Life?
Looks like I'm going to have to replace my tires at only about 20-30k. (thats in kilometres!) I bought these 2 years ago, I have never had to buy 2 sets of tires for one vehicle. So do you think the grill guard, would cause this premature wear? The tires were rotated on a regular basis, there's no camber wear, I haven't been doing burnouts or anything stupid like that. The tread wear on all tires are all even. :S I'm pretty much stumped whether or not I should I sell my Manik Grill guard.
February 29, 2004, A couple of days before the grill guard was installed
Monday, October 04, 2004, just over 6 months after it is installed
A lot of tread is gone for 6 months...
__________________
2005 Toyota Tacoma Access-Cab 4x4 w/ TRD Off-Road Package
33" Goodyear MTR's
3" Toytec Lift
Clear Headlights
Quick Pic of the Taco
My Old Toyota 4Runner Limited, Check It Out!
Vato Loco is offline
Sponsored Links
To remove this ad, register today!
Old 01-02-2005, 08:37 AM   #2 (permalink)
CrazyDiamond's Avatar
Looks to here like the outside edge of the tread is worn more than the center...is that true when you look at them? If so, could be underinflated chronically, or the toe-in on your alignment could be out of adjustment. Incidentally, NO, the weight of a grille guard isn't going to measurably affect your tread life. Not at all. How are the back tires?
__________________
Adam Majkowski
majikmd@gmail.com
93 4x4 Pickup, 22re, Header, 2.5" exhaust, Eagle 058 alloys + 31x10.5x15 Firestone Destination M/Ts, ECT mod, ProComp AAL, full undercoating + other fun stuff :-)
CrazyDiamond is offline
Old 01-02-2005, 08:50 AM   #3 (permalink)
firemedic's Avatar
Shouldn't have that much effect.
__________________
Ben Silva
96 Lexus LX450, 125k, front/rear OEM diff locks, CDL switch, Pin 7 mod, power points, wired 850w inverter, jdm "oh crap" bar, OME heavy (850/863) lift, 285/75/16 Cooper STT, spare tire lift mod
98 Lexus LX470, 135k, Britax car seat ;)
TLCA member #14300
Camas, WA USA
firemedic is offline
Old 01-02-2005, 09:09 AM   #4 (permalink)
FilthyRich's Avatar
It should have no effect. at least nothing like what you are experiencing. I would check your air pressure. That looks like the culprit
__________________
Eric
88 4runner
Quote:
Originally Posted by AxleIke
"Just wheel what you got until it doesn't cut it anymore".
FilthyRich is offline
Old 01-02-2005, 09:29 AM   #5 (permalink)
ChickenLover's Avatar
There is no way the weight of your grill guard could be responsible for the premature wear. I think you are looking at an alignment or air pressure problem.
__________________
95 4Runner, 3VZE , 141k, 4WD, Auto. (Head gaskets replaced at 106k)
ChickenLover is offline
Old 01-02-2005, 09:43 AM   #6 (permalink)
Paul H.'s Avatar
What are your tires inflated too? I agree with evryone else. Inflation is probably the culprit.
__________________
92 4Runner SR5 V6 4X4
Skyjacker Nitro shocks, Pro-Comp steering stabilizer, clear bumper lenses, lund windjammer, OME standard coils, ISR mod, inlet pipe removed, Bushwaker Fender Flares.
2002 Tacoma Prerunner V6 Xtracab. Lund Intercepter bug guard, rear glass sunshield, Bilstein shocks on rear.
2004 Honda CRV EX stock belongs to wife.
Quote:
Originally Posted by habanero View Post
I did a lot of masticating today.....and now I'm going to go do some more.
Paul H. is offline
Old 01-02-2005, 01:06 PM   #7 (permalink)
Noliwan's Avatar
Send a message via AIM to Noliwan
I have the manik grille guard on my truck also with over 45k when first installed-- no signs of tread wear on my tires--I rotate regularly as you do--- must agree with everyone else-- underinflated tires or just bad alignment... have both checked out... BFG tires are great-- I have the same ones you are using on my wifes RAV4 with over 50k and a pretty good decent amount of tread life left...
__________________
2000 TRD 4Runner SR5 4WD
My Mods
Noliwan is offline
Old 01-02-2005, 01:14 PM   #8 (permalink)
Send a message via Yahoo to humanoid
Have a WAAG on my and went over 80K miles on my first set of tires. You could have a toe-in/out problem or a camber problem. Just my 2 cents.
__________________
'99 Taco PreRunner V6 3.4L
humanoid is offline
Old 01-02-2005, 01:23 PM   #9 (permalink)
lee
lee's Avatar
Send a message via AIM to lee
ive owned my runner since oct '03, it has had a grille guard from day one. when i bought it, the tires were pretty much dead, and the dealer threw on the dulop radial rover a/t's i have now. treadlife has been great (little to no wear), and there is no need to change my tires whatsoever almost 20K later.
i dont think the guard is the culprit.
lee is offline
Old 01-02-2005, 02:17 PM   #10 (permalink)
I've got a pretty heavy bush bar and winch off the front of my tacoma and I got just over 90,000KM out of my last set of tires - sounds like premature wear to me.
Masato
__________________
99 Tacoma 4x4
Masato is offline
Old 01-02-2005, 03:03 PM   #11 (permalink)
Vato Loco's Avatar
I had the tires for about 6months right before I put the grill guard on, with regular rotation and etc, it had no sign of wear until I put the grill guard. If anybody's interested in a 96-98 Manik Grill Guard just let me know. Thanks for all your inputs.
__________________
33" Goodyear MTR's
3" Toytec Lift
Clear Headlights
Old 01-03-2005, 05:49 PM   #12 (permalink)
hilandfrog's Avatar
Quote:
nice patch, what years were you there? I was at ONE from 90 to 02.
VR
Repo
__________________
01' tundra.... "must have a little green man under the hood that controls things"
?? 4.7 liter ??
15mpg adv
plush ?truck?
"Keep both eyes open, keep the front sight focused and use good trigger control"
hilandfrog is offline
Old 01-03-2005, 05:59 PM   #13 (permalink)
Vato Loco's Avatar
Quote:
VR
Repo
Huh...
__________________
33" Goodyear MTR's
3" Toytec Lift
Clear Headlights
Old 01-03-2005, 06:11 PM   #14 (permalink)
lee
lee's Avatar
hes referring to his avatar.
lee is offline
Old 01-03-2005, 06:16 PM   #15 (permalink)
Vato Loco's Avatar
Quote:
oh ok My bad...
__________________
33" Goodyear MTR's
3" Toytec Lift
Clear Headlights
Old 01-03-2005, 08:02 PM   #16 (permalink)
firemedic's Avatar
VR
Repo
Well who the hell are you? I was at One from 94-98. Foxtrot in 96, Bravo in 97.
EDIT: I wasn't a pecker checker back then...
Chris Forrest (ST-1 same time as me) is in Montana now too.
__________________
Ben Silva
TLCA member #14300
Camas, WA USA
Old 01-03-2005, 09:02 PM   #17 (permalink)
hilandfrog's Avatar
I'm repo, I got to ONE Apr. 90, Stationed Key West 96, back at 0NE 00 Then tradet, who the hell are you. I don't know chris but always nice to have a fellow toad around the hood.
Repo
__________________
?? 4.7 liter ??
15mpg adv
plush ?truck?
Old 01-03-2005, 09:10 PM   #18 (permalink)
jimbo74's Avatar
Send a message via AIM to jimbo74
a grille guard will add more weight to the front end... however that should have no effect on the tires as long as they arent overlaoded.. im i am sure no tire is going to get overloaded on a stock vehicle thats got maybe 100 extra pounds on it... its most likely mroe a tire issue or crappy tires....
jimbo74 is offline
Old 01-03-2005, 09:11 PM   #19 (permalink)
jimbo74's Avatar
also looking at the type of tires you have... that mileage is on par with what those tires perform at
jimbo74 is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
