does a lift fix the sag?
ok so im really getting tired of my rear sag. i would like to get rid of it, but im hoping to get a 3 or 4" lift near the end of spring or early summer. my question is that if i get a lift, would it fix the sag? because i don't want to fix the sag and then get a lift that would fix it. anybody? thanks
KEVIN
KEVIN
Saggy rear???
I had the same problem with my 'runner. I bought rear coil spring spacers on-line for about 80 bucks and it fixed the problem. It took about 1 hour to install. Kind of a pain since numerous torsion bars and suspension had to be unbolted, but a cheap quick fix!! I think they were called pro-comp or something of the sort. It has been a while. Good luck...and one more thing, leave the current spacer on, it is a 1/2 thick ring around the bump stop above the spring. This will lift the rear about 1 1/2 inches if you buy the 1 1/4 inch spacer.
sweet thanks guys. yes i will lift it once im out of detb from buying it. so that will probably be the spring of 04. i've only had it for like 4 months
Since this thread is about lifts...
And sorry to take over but what is the best body lift for a '95 Runner? I went on 4wheelparts.com and saw a couple made my Performance Accessories but *I* had never heard of them before but I am a nOOb to the lifting business...any recommendations on brands and places to buy them?
Thanks guys!
Thanks guys!
09-04-2015 09:27 AM
coffey50
07-28-2015 10:55 AM
Vargntucson
07-04-2015 12:15 PM
