Do You Have An AFR Gauge?
Old 02-22-2015, 09:45 AM
oregon taco's Avatar
Do you have an AFR gauge?
If so, what brand?
Where is it grounded?
Where is it drawing power from?
Where is the controller mounted?
Old 02-23-2015, 09:14 AM
Texas_Ace's Avatar
I do, only needed if you are boosted and then only if something more then a stock pulley TRD supercharger. Not needed at all on 01+ trucks.
Search around for a good deal on a wideband, most work fine, check review for whatever you find.
Follow the instructions for wiring, power from the battery through a fuse is good, switched power through a relay wherever you can find it, cigarette lighter in most works.
Mount it wherever you want. I prefer out of the way installs nowdays. I actually prefer widebands that don't have gauges myself, just hook it up to a computer/phone when you are tuning, otherwise it is just in the way.
Old 02-23-2015, 07:37 PM
sleeper2002's Avatar
I have an AEM wideband setup and love it. Very fast response, easy to read and accurate. I also like the interchangeable bezels and face plates. I ran a relay and power point setup: I used a 20 amp capacity relay and wired (coil side of relay) it to the cig lighter. The other side of the relay (high amp draw side) is wired to power a small (5 location) fuse block on the firewall, this way the gauge is on a switched source. The ground is on the firewall using a simple ground block. As for the gauge, I mounted it using the 2 pod setup from Lotek.
Old 02-24-2015, 08:41 AM
vasinvictor's Avatar
I have the same AEM wideband. I have done everything this guy ^ did. Relay on a switched ignition source. The gauge is just wedged in the front left windshield between the dash and windshield. It's right next to my progressive meth controller gauge.
Old 02-24-2015, 08:44 AM
Texas_Ace's Avatar
You should totally get a piller pod. You can get universal ones that work, thats what I am using. Way better then just shoving them someplace lol.
Old 02-24-2015, 08:46 AM
I know, this truck is gonna nickle and dime me to death.
Old 02-25-2015, 02:31 AM
Robb235's Avatar
If you have a California emissions truck, it has a wideband up front, and you can use an OBD2 scanner, and correlate the reported voltage to AFR using this chart.
Old 02-27-2015, 01:12 PM
Do you have the link for that table? I tried to look at the picture, but it's a little fuzzy
ashamsuddin
17
01-13-2023 03:17 AM
kawazx636
10-06-2021 03:03 PM
zanzabar0
10-11-2015 02:56 AM
Jdgarrison
10-01-2015 05:22 PM
dbollier123
09-29-2015 05:23 PM
Quick Reply: Do You Have An AFR Gauge?
