Do I need alignment Service for my 2001 4runner?
Hi All,
I have a 2001 4runner with about 110K on it. I'm just wondering if I need alignment Service at this time. I replaced all 4 tires at costco about 6 months ago and I have never had alignment service for my truck. Toyota dealer is charging for $99.95 (4-wheel). Should I go ahead and do this service with the dealer or do I even need it?
Thanks,
Henry
Thanks,
Henry
doe it pull to one side while driving? slight vibration at high way speeds? it wont hurt since you got new tires and obviously you have never had one.
1. dont go to the dealer
2. go somewhere like sears or another trusted shop that will warranty the alignment. i get mine done at sears and its a 6 month warr on it, so i take it back at 3 months and just before it expires cause i wheel my runner and it works its way out from time to time
Thanks,
Henry
Guest
you dont need a 4 wheel alignment. you have a solid axle in the rear. IF you had rear ifs, then you would need 4 wheel alignment.
the only alignment you need is a front, 2wheel alignment. dont let them tell you differently.
Yeah, I love it when places come up with crap like that.
To answer your question, as long as the vehicle tracks straight, has no wheel vibrations and the tire wear looks normal (ie evenly worn, not feathered/cupped/heavy wear inside/heavy wear outside/etc) then you probably don't need to do it. If you do have them go through with it, make sure to tell them in advance you want a machine printout for the specs it was set to (that way you know exactly what the steering is set to and they can't pull a fast one later if there is an issue).
i suggested that they fill my tank before they wash it, they did.
no more alignment issues and it never cost me any $$$, just time.
I placed an order for brembo rotors & brake pads... planning to replace them when the parts arrive somtime next week...should I wait to do alignment after replacing the rotors and pads or it does not really matter? I can take my truck to Les Schwab to do alignment for around 50 bucks.
Thanks,
Henry
Thanks,
Henry
Thanks,
Henry
Thanks,
Henry
rushw
07-18-2015 01:46 PM
mengquis
07-13-2015 10:39 AM
