Do 3.0L TD headers and turbo fit 3.0L gas engines?
Hey all,
I was just brainstorming a bit. Would the headers and turbo from a 3.0L turbo diesel (they do make a 3.0L diesel, right?) bolt up to a 3.0L gas block? Might be kinda interesting. Do these engines use the same block, etc?
I wonder what the power increase would be.
You all's thoughts would be cool.
Have fun all.
DH6twinotter
Have fun all.
DH6twinotter
The 3.0 diesel is a 4-cylinder if I remember right. The 3.0 gas is a V-6.
Even if they had the same configuration, since the diesel operates at much higher chamber pressures, when the exhaust would get dumped into the header, it would expand and create a larger volume of gasses than the gas version. Hence, you'd need a much larger header and exhaust pipe to keep the back pressure at an acceptable level. Check out the pipe on Ford/Chevy/Dodge diesels and compare them to a comparably sized gas V8...the diesel will be larger.
Jnkml
07-06-2015 01:20 PM
