Distributor trouble
Old 06-03-2005, 01:11 PM
ttr125mar's Avatar
Distributor trouble
I took my distributor out to put it in a new engine but it doesnt fit in the hole on the head. The gear on the distributor can make it through the hole if I wiggle it but as soon as it hits the fat round metal it wont fit. It fits fine in the old head (slides right through) but it wont budge for anything. What is wrong? What should I do?
Thanks,
Mario
Old 06-03-2005, 06:16 PM
DudeBud's Avatar
sounds like the o ribg geting hung up give it a love tap
Old 06-03-2005, 07:00 PM
rugerm44's Avatar
Rub vasaline on the o ring.It wouldnt hurt to put a new o ring on it anyway.
Old 06-04-2005, 08:57 AM
ttr125mar's Avatar
Its not even close to the o-ring. The o-ring is in back, its getting stuck on the metal (right after the gear it's skiny round metal then a fat round metal that has a little downward slop to it, that is where it wont go in).
Thanks,
Mario
Old 06-06-2005, 10:55 AM
ttr125mar's Avatar
Anyone? Would sanding or honing it out be alright to do?
Thanks,
Mario
Old 06-07-2005, 08:56 AM
Marc's Avatar
You could measure the hole in the head and the part on the distributor and see if they are the same. If they are I suppose a bit of filing on the distributor wouldn't hurt anything.
Are you sure it's not the alignment on the gear that's holding you up?
Try moving the rotor shaft a bit each way.
JonG85
01-18-2023 04:31 PM
LittleUgly
15
01-02-2020 01:30 PM
voiddweller
10-02-2015 07:47 AM
Matthew Perez
09-28-2015 05:43 PM
seab1209
09-03-2015 05:41 PM
Quick Reply: Distributor trouble
