Distributor Timing Question
I just installed a new distributor in my 3VZ-E.
On purpose I installed it 1 or 2 degrees more clockwise than it was before (i.e. I turned the distributor a bit more to the right).
Have I advanced or retarded my timing?
It depends on the rotation direction of the distributor. If the distributor turns clockwise and you turn the distributor housing counter clockwise then you will have advanced the timing.
Avenged
07-09-2015 07:55 AM
1600, 22r, 73, advance, clockwise, counterclock, counterclockwise, distributor, timing, ve, yotatech
