Did the Deckplate mod. How long should I wait?
Old 06-06-2005, 12:03 PM
Gangus2006's Avatar
No-one I knew would lend me a jigsaw, so I had to improvise. I took a soldering iron and poked holes on the line i traced, hten beat it out with a hammer. Layed RTV around hte edge, bolted the DP in place.
How long should I let the RTV to cure before driving with it? I had to put the airbox/MAF back in because my dad was on his way home, but Im going to wait to start the engine.
Gangus2006 is offline
Old 06-06-2005, 12:12 PM
Yobroe's Avatar
Dude, it isn't going to hurt your engine to run it now. You shouldn't have to wait any more than an hour and that is probably even too long. Just run it without the plate in, which is what you want to do anyway...lol. It will be louder, you will get better throttle response, it will feel faster, but it isn't. You won't get any better mileage either, but it sounds cool.
Yobroe is offline
kevin444's Avatar
Id give it at leat 2-3Hours to be safe. Is the RTV sensor safe? Good luck on it! Make sure to remove the 20amp efi fuse before starting her up.
kevin444 is offline
Old 06-06-2005, 12:27 PM
rimpainter.com's Avatar
Hey, mines 15A! Maybe I should do a 20A fuse mod...
rimpainter.com is offline
Old 06-06-2005, 12:29 PM
Gangus2006's Avatar
Yea, I had to go to like 3 different auto parts stores to find the sensor safe stuff. I did the ISR mod last week already.
I know its not going to give me any performance. I just want the sound anyways.
I burned a half a tank of gas in one day driving a total of maybe 10 miles. WOT must run really damn rich.
EDIT: I pulled the ECU-A and ECU-B fuses in the cabin (10A and 7.5A). Where is this 15 or 20A fuse you guys are talking about?
Old 06-06-2005, 12:33 PM
Gangus2006's Avatar
I just didnt want the MAF to pick up any fumes and throw a CEL. Seeing the 4Runner I did this mod in isnt mine...
Old 06-06-2005, 01:12 PM
kevin444's Avatar
Its the small fuse and its the one next to the battery. Should be yellow? Just pull it out wait a couple secs and put it back in.
kevin444 is offline
Old 06-06-2005, 01:13 PM
kevin444's Avatar
More current!!! moooooo powwwaaaaa
kevin444 is offline
Old 06-06-2005, 01:15 PM
Gangus2006's Avatar
Ok I found it. Mine is 20A too.
Revved the engine a little. It sounds a lot nicer than just witht he airbox open.
Old 06-06-2005, 01:19 PM
kevin444's Avatar
ive remembered my old 98 4runner was a 15a fuse and the 99-02's are 20A whatsup with that? hahaah
kevin444 is offline
jasonty
41
12-23-2018 01:00 PM
jashoeuh
11-26-2017 07:01 AM
Jcrawl94
10
10-24-2015 04:34 PM
lectric80
08-11-2015 12:02 AM
Massmayhem247
07-18-2015 05:46 AM
Quick Reply: Did the Deckplate mod. How long should I wait?
