Diagnose this noise please. - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 02-20-2006, 10:22 AM   #1 (permalink)
sabre's Avatar
Send a message via ICQ to sabre
I used my voice recorder on my mp3 player this morning to record the sounds from my truck. 2001 sr5 with 59k. It started a few weeks ago. Sounds like static or rattling. Inside the truck it sounds as if something is loose in the plastic around the cd player but its not. It starts around 35mph and goes away on braking. I dont tend to notice it if its raining. Like something gets wet and it stops making the sounds. Any input would be great.
1st file
2nd file
Thanks
__________________
'01 SR5 4x4 Millenium Silver
Added
♠ Roofrack ♠ Sunroof wind deflector ♠ Ventvisor ♠ Clear corners ♠ Clear turns ♠ Clear bug deflector ♠ Color matched running boards ♠ JVC-KD-SH99 MP3 player deck (Silver of course)
Foremost Web Hosting
sabre is offline
Old 02-20-2006, 10:48 AM   #2 (permalink)
Flamedx4's Avatar
It sounds like John Lennon if you play it backwards...
__________________
All my Yotas are gone. Stuff to sell: http://www.yotatech.com/showthread.p...39#post1009839 -Phil
Flamedx4 is offline
Old 02-21-2006, 05:16 AM   #3 (permalink)
sabre's Avatar
Noone has had this sound? I have been reading about greasing up zerks and was wondering if this was the culprit? My truck sopunds like a race car also. Loud noise uder the driver seat when accelerating. That combined with the rattling is getting me nervous. I guess ill have to bring it in somewhere.
__________________
Added
sabre is offline
Old 02-21-2006, 06:24 AM   #4 (permalink)
Rick F.'s Avatar
Location: Far western Kentucky (transplanted from central PA)
Send a message via AIM to Rick F. Send a message via Yahoo to Rick F.
Darn near impossible to diagnose that just from your sound clips. We'd just be WAGing (wild ass guessing). If you've ruled out mechanical noise from the CD player, have you tried pulling the CD player fuse to see if it's an electrical noise? That's a good example of a WAG...
__________________
'00 SR5, Desert Dune: 4" Deckplate, Amsoil TS-115, Bilsteins, Brembo rotors w/Performance Friction pads, Fiam Highway Blasters, Sylvania Silverstars, Hella Micro DE Fog Lights w/Hella Yellow Star Lamps - SOLD 1/24/09
'08 Sport, Salsa Red: Hella Optilux fogs, Silverstar Ultra Hi beams. Pending: Borla dual catback, CAI, shocks
Rick F. is offline
Old 02-21-2006, 09:52 AM   #5 (permalink)
sabre's Avatar
Quote:
I understand. I was just hoping someone experienced this. There has been talk going on about the zerks needing to be lubed and was hoping for some insight as to if this is the sound they get when they arent lubed. Shot in the dark, I know but worth it at a place like this. Seems like someone at sometime has had a problem another member comes across.
__________________
Added
sabre is offline
Old 02-21-2006, 11:40 AM   #6 (permalink)
Flamedx4's Avatar
I listened and listened...
Were you driving or just in neutral at the time?
I agree with Rick, from those sound clips it's not really possible to tell much.
But it sounds like I hear a couple of things that I wouldn't like. First, the exhaust seems simply louder than it should be, but the mike may just pick it up that way. Second, there's a sort of rattly/vibraty sound that sounds to me a bit like a faulty muffler (internal baffle came apart sort of noise.) But at other times it changes and sounds more like a harmonic vibration - heat shield for the cat rattling - something like that. Then at other times it sounds more like speaker static. Really hard to guess. You are there, can't you tell where it's coming from? An old trick that may help - get a paper towel tube and use it like a stethoscope to isolate the sounds.
Then there's a spot where it sounds a bit like there's a u-joint grinding. (This of course would only happen if you were driving when you made the recording.)
By the way, the zerks don't need grease, the zerk fittings allow you to grease things that DO need grease... (jus' givin' you a hard time.) Ball joints, tie rod ends, driveshaft, u-joints etc. Although on newer rigs so many of those don't have grease fittings anymore - they just have to be replaced when they age out.
__________________
Flamedx4 is offline
Old 02-21-2006, 12:01 PM   #7 (permalink)
sabre's Avatar
This was recorded while highway driving. I cant figure out where it is coming from because it only happens once I hit 35mph or so. I was oing between 60 and 70 when I recorded it.
The exhaust does sound louder now. Like a sports car. Its a roaring type noise in the drivers seat.
The rattling/static sound is what happens at 35mph. Goes away when I brake. Everything on the recorder is what I hear in my truck. Wish I knew more about this stuff but I am not mechanically inclined when it comes to autos.
__________________
Added
sabre is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
help me diagnose this sound bluechip932 95.5-2004 Tacomas & 96-2002 4Runners 14 04-06-2007 11:39 PM
Help me diagnose a vibration li_runner 95.5-2004 Tacomas & 96-2002 4Runners 2 08-15-2006 01:42 PM
Help diagnose noise curtiswyant 86-95 Trucks & 4Runners 4 06-29-2006 01:46 PM
Help me diagnose "roaring" noise from front driver area mjwalfredo 95.5-2004 Tacomas & 96-2002 4Runners 33 03-02-2006 03:33 PM
help me diagnose jacksonpt 95.5-2004 Tacomas & 96-2002 4Runners 2 09-06-2002 07:53 PM
2009 InternetBrands, Inc.
