| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Dexron in manual transfer case and 4wd shifting problems?
__________________
94 4runner SR5, V6 3VZE, 5 speed Completely rebuilt engine with Toyota parts at 147k miles Downey Coils, Aisin manual hubs, Cowl Louver mod, Hella 500 fog lights Yeah, I know, not many cool mods here |
#2 (permalink) |
Umm I would say yes. I would not only make them drain, but flush it and refill.
Other reason to DIY if you are able to.
__________________
Brad Work is for those who don't know how to plunder!! 92x-cab dlx 4x4 22RE, Pacesetter header, everything else is so stock it's not funny, cause I don't have the money! 04 F150 FX4 SuperCrew |
#3 (permalink) |
I will make them flush and refill. I seem to remember somebody talking about synchros and how their performance is affected by the oil that's in the transmission and/or transfer case. Can the difference between Dexron and gear oil totally mess up how the synchros work in the transfer case?
__________________
#4 (permalink) |
OK, after some reading in my repair manual there seems to be some small differences to the transfer case between the AT, the MT and if you have ADD or not. Could it be that they mounted a transfer case from an AT or a non-add vehichle? And is there anyway I can figure this out by serial numbers on the transfer case without picking it apart? Any help/info is appreciated so I have something to put on the table when I complain to the transmission shop.
__________________
#5 (permalink) |
No synchomesh in the t-case, ATF is probably very thin to use in it. Good old 75W90 GL4 or GL5 oil is fine. For the shift on the fly, ADD I assume? If so, check that the shop did not disconnect any of the ADD wiring on the case or at the front axle or the VSVs that switch the front axle in and out.
http://www.off-road.com/toyota/tech/add/index.htm
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#6 (permalink) | |
Quote:
__________________
#7 (permalink) |
Is it ADD or manual hubs? If ADD, the lube may have something to do with that. There is some sort of synchronizer mechanism for that to spin up the front driveshaft.
__________________
#8 (permalink) | |
Quote:
__________________
#9 (permalink) |
get your vin from the ownership or front dash if you can make it out and go to 4crwalers site. he has a section to help decode your vin to see exactly what trans you have. my 93 uses atf in the t/case, but most others use gear oil. find out for sure what is supposed to be in there, then get the trans shop to rectify the situation.
lee
__________________
93 sr5 v6 auto, 4x4 Photos http://s866.photobucket.com/albums/a...albumview=grid there are quite some attractive ladies on here with Toys. (compliments of ironmike) ifsc 3(.0) http://tlca.org www.of4wd.com www.sontt.com |
#10 (permalink) | |
Quote:
__________________
#11 (permalink) |
no the trans and t/case do not share the fluid, they are separate, sealed units. your trans code should be a340h and use atf. it may take some digging or prodding of the stealer to verify it, once you know, you are good to go.
lee ( hey, blondie!!)
__________________
#12 (permalink) |
auto takes atf, manual takes gear oil
auto shares fluid with the trans, manual does not
__________________
88 4Runner. 350 V8, R150 5-speed. SAS, 36" TSL's, elocker rear |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 4WD Transfer Case Actuator | Potomacduck | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 09-25-2007 06:25 AM |
| ATF - Is Dexron III OK when the manual calls for Dexron II? | scottc | General Vehicle Related Topics (Non Year Related) | 3 | 04-12-2007 12:28 PM |
| transfer case shifting problem | cig4059 | 86-95 Trucks & 4Runners | 5 | 02-06-2007 09:32 AM |
| Transfer Case Problems | deSCHUTTER | 86-95 Trucks & 4Runners | 3 | 02-04-2007 01:56 PM |
