Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Defroster
i've got a 93 and the rear defroster barely works even just on fog and the one in the rear side window doesn't work at all... any ideas?
chris
__________________
CB |
| Sponsored Links |
#2 (permalink) |
If I remember tommorow I will look in one of the toyota manuals at work and get more information on it. My rear defrost wasn't working so I looked in the manual troubleshooting guide and it had a list of possibilitys. Mine ended up being that I had no fuse in for it ( I think I thaught it was a spare at one time ) :pat:
#3 (permalink) | |
Re: Defroster
Quote:
__________________
'95 Runner, Downey HD Coils, Bilsteins, K&N air filter, airbox mod, Yakima roof rack, Sony Mobile ES and MTX system: head unit/10 disc changer/eq/speakers/subs/amps |
#4 (permalink) |
Defroster
The "lines" in the side windows is the anteannas.
If your rear defrost is not working, most likely you have a loose wire in the tailgate. Pull the rear cover off the tailgate, remove the metal plate behind that, and peal back the plastic vapor barrier on the drivers side. You will most likely find 1 of the 2 wires that attach to the lower drivers side of the galss are broken. Repair the connection and you will be frost free!
__________________
1993 SR5 4wd TJM-15, 2" Body Lift, K&N FIPK, Maniac Metalwork Sliders, Bushwacker Flares, Saggy Butt RX: Bilsteins and Downy HD Coils, Yakima Load Warrior, Hella 500s, Leather Interior. |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 88 22re Overheats with heater/defroster on | reefcrack | 86-95 Trucks & 4Runners | 12 | 05-03-2007 12:06 PM |
| Rear Defroster Switch | iceman81005 | 86-95 Trucks & 4Runners | 1 | 01-11-2007 02:32 PM |
| Rear Defroster not working? | gapguy | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 12-12-2004 02:18 PM |
| Rear Defroster won't work | Flojules | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 11-28-2003 11:55 PM |
| Rear Window Defroster | Cebby | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 12-10-2002 07:28 AM |
