Deckplate mod...Need Help???
This is my first post, so I'm somewhat of a newbie to these forums, but not a newbie to Yotas.
I just completed the deckplate mod and I revved up my engine when I was finished and my engine stalled. I put the deckplate in and no stall. Any explanations to as to why this happened?
give the ecu a reset?
clean the maf?
^^^ Ditto.
The ECU needs to relearn, pull the neg batt terminal for 1 minute and try it again.
I bet it won't stall with the deckplate out after that.
You should probably clean the MAF soon as well.
maf sensor is real easy to clean just take it out spray with electrical contact cleaner and let it dry for a few mins also double check all the wiring
MAF cleaning:
http://www.4x4wire.com/toyota/mainte...tenancep5.html
Once you pull the neg batt terminal, the ECU has been reset.
rimpainter.com
35
07-16-2003 08:41 PM
Bob_98SR5
04-08-2003 10:14 PM
ryan k
14
03-06-2003 12:29 PM
