Deck Plate Mod Completed!!!
I just completed the deck plate mod. The toughest part, as everyone has pointed out, is cutting the hole with a Dremel. It made a hell of a mess, and a very non-uniform circle. I used a shop vac afterwards to get everything out. I pulled the 20 amp fuse before I started.
I got the deck plate for $7.00 from a local marine, the sensor safe sealant for $1.99 for a small tube (more than enough), $.84 for the six screws. $9.83 for this mod was not a bad deal, if you have all the tools already, and some average skills.
I was not able to put the screen on the back side with the clamp. The waffle material made it so I could not get the screen and clamp on. Is the screen a necessity, or more of a "nice to have it"? It doesn't look like it would get much in there by way of large debris or bugs or anything due to the placement of the hole ( it faces the headlight and washer filler tube).
I took a quick spin down the street, and noticed the "roar" doesn't kick in until you get the RPMs goin (which is what I have read). I will post more once I have a chance to get her up to cruisin speed!
I didnt haven dremel handy so i used a jig saw. If you take your time cutting the hole (about 5 mins) then a jigsaw works perfectly. I didnt put the screen on mine either and i probably wont. If i see any large bugs in there i will just clean them out. The air filter will catch them.
I never put a screen on either of my deckplates. I personally dont think its necessary. Its just a preference thing.
If you have an air filter, the screen is pointless. My opinion of course.
the screen is just for bugs and leafs..i have found bugs and leaves in my engine but not near the intake..i haven't seen anything stuck on mine or anything...so it doesn't really matter..
I did my Deckplate last night too, and I also found that the Dremel was a bit of a pain. I was able to put the screen on and secured it with a large Zip Tie. To me it is just the little bit of added insurance.
I did my mod in conjunction with the silencer removal mod. There is definitely an added roar, and a noticible increase in acceleration. I seem to have gained back all that I lost by going to the bigger 285/75/16 Revos. Now I gotta learn not to step on it to hear the roar!
Yee Ha!:bounce2:
Yee Ha!:bounce2:
[QUOTE]Originally posted by <96 Runner>
[B]I hope everyone is using the circle-cut attachment for the dremel, it makes it a whole lot easier!
Yes, I bought that today..it made it easier, but not easy. It wanted to skip around a bit on me. You also need really good light to see the circle you drew to cut out the hole.
I helped my buddy perform the deckplate this weekend and we used the tools you used too. It helps but for future reference, you really need to do two things:
1) stabilize the air box either in a workbench (like a B&D workbench) or have someone else hold it.
2) grip the dremel really hard. The bit will jump/skip when it hits the internal waffle ribs inside.
Better yet, suck it up and buy the appropriate sized hole saw for your drill.
Bob
Bob
Bob
Bob
Bob-
Yeah, those are good pointers to future deckplaters out there. I always cut the hole a little smaller, then used coarse sanding bits get the extra size I needed. Of course, I am a big man with my 6" deckplate compared to all you 4 inchers.
Actually the hardest part for me was getting the lower bolts out, probably because we didn't have an extension for the sockets haha. Oh also sanding the edge of the hole just so the deckplate fits perfectly. Cuz I cuz the hole small on purpose to make sure I had the tightest fit.
theking11863
03-19-2016 09:36 PM
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
