Deck Plate lowered my mileage...help
I have the deck plate modification and a K&N filter in my box. I noticed a drop in my gas mileage...any suggestions? Do I need to wall off my engine compartment so I'm not sucking in hot air? Would a Amsoil filter be better? Finally, should I unhook my mass air flow sensor? HELP
I know it sounds real cool when you stomp on the gas between 4k-5k rpm..but that is what is causing the lowered MPG... if you drive normal it will not be that bad.. I have a log of my milage and the first few tanks of gas was a lot lower ( I believe because the computer has to get used to it) and tha fact that it counded so damn cool to me
BTW, I am using the amsoil filter..not the K&N..I do not know it will make a differience..but I ma not an expert..I have never used the K&N
Thanks Man...that really helps!
I rarely take my Runner past 3.5K, but I do admit I was playing a bit with my new HP! I think I am going to try the Amsoil Filter....seems like lotta folks like em'
Like I said, I have never had a K&N..but I did have the amsoil for a couple of weeks before I put in my deckplate..and it was a world of differience over the stock filter...
Hint: the amsoil won.....that's why we all use it.
This is sort of tangential, but what size deck-plates did you guys all go with? I recently bought a 4", have't gor around to installing tho. Was hoping for something bigger, but the next step up was "8.
I'm hoping to get it in tomorrow-wanna see how it helps on my up-coming cross country trip (already got the new exhaust on) mileage wise, if at all.
97'. I installed mine about 6 weeks ago and I've been averaging ~16-18 mpg street/fwy ever since. Not much of a chance from whence i didn't have the mod. Granted, I do floor my truck at every on-ramp just to hear the sound.
I go between 16.5-21 that is both before and after deckplate mod
4 Inches will do!
Originally Posted by humanoid
Not to hijack the thread but.... aw, what the hell... Where in SoCal did you get the deckplate. Pondering about going back to my stock airbox and needed to know where to get it, thanks!
Order from here, mine came in less than a week and under $15.00 out the door.
hell, what did you avarage before?
About the same actually. I didn't see much difference in fuel consumption...
I live in Ontario (california)... theres a marine shop 5 min away from me
Just grab the yellow pages and look up marine supply, I think.
Originally Posted by JASPER99
Don't think you will be able to fit more that 4" in the air box! Let me know if you have any problems and I will see if I can pull up the instructions I found on the web about how to install. Good Luck!
I just looked at my chart and I avarage 18.432349 mpg in all situations.
