dealer installed alarm ignition starter cutoff problems - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 02-20-2006, 10:18 PM   #1 (permalink)
KyleT's Avatar
my car is a 1996 4runner limited
I have the dealer installed (im assuming that it is, there is a thing in the glove box with the paperwork about it being added for 500 bucks or something) alarm on my car and recently it has decided to activate the ignition starter cutoff feature. I never use the alarm, no need for it and i dont want the problem to get worse. has anyone else had this problem?
I go to start the car, turn the ignition, it turns everyhting on (ac, radio ect..) but i get nothing more when i click to the start position, no lights dim, no solonoid clicks, nothing. I ususally have to let it sit for a couple of hours and I guess it resets itself. i have nearly been late to work and other stuff, trying to find other rides.
my question is, where is the alarm box located? I could not find one for the life of me, and second, how can I disable this feature? I am partial to just removing it entirely, but I would like to use the keyless remote thing if possible.
(sorry if its on the wrong section, i searched too)
__________________
- Kyle
Former Owner of -
1996 Sunfire Red Metallic 4Runner Limited updated 10/31/06
OEM/TRD Lift Kit #1 from Sonoran Steel with 1 Top-out spacer - Lexus GX470 rims - 295/70r17 Nitto Terra Grapplers Yukon 4.88's, E-Locked Rear, Waiting to blow up front diff #2
KyleT is offline
Old 02-20-2006, 10:36 PM   #2 (permalink)
bigacuralvr's Avatar
Send a message via AIM to bigacuralvr Send a message via Yahoo to bigacuralvr
its probably pretty easy to find, either under the steering column, or in the drivers kick. Try flashing the lights (high beams) before trying to start the car. If it consists, take it to BestBuy or Circuit and get it uninstalled...or get another keyless installed. They'll have to un-install your old one for the new one. Where are you located? If you're around here...I'd rip it out for $5.
Brett
bigacuralvr is offline
Old 02-21-2006, 12:21 AM   #3 (permalink)
KyleT's Avatar
i didnt think about flashing the high beams. it just gets irritating not knowing if it will start or not.
i looked all up under the dash and didnt see anyhting like an alarm box, ill look tomorrow again i guess.
__________________
- Kyle
Former Owner of -
KyleT is offline
Old 02-21-2006, 12:30 AM   #4 (permalink)
gapguy's Avatar
Send a message via AIM to gapguy
Do you have the two button toyota remote? If so, the alarm box is under your driver's seat. Good luck..
__________________
2008 Mini Cooper
gapguy is offline
Old 02-21-2006, 05:24 AM   #5 (permalink)
MTL_4runner's Avatar
Send a message via AIM to MTL_4runner
Do you know if it is a factory alarm or aftermarket?
Might want to take a look at the pics in my signature for alarm install to give an idea of what you are looking for.
__________________
- Jamie
1996 4Runner SR5 4X4 Auto
Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift
Best OBD II scan tool I have used!.
.....and I am AMERICAN!
MTL_4runner is offline
Old 02-21-2006, 09:05 AM   #6 (permalink)
KyleT's Avatar
i am 99% sure that its the dealer installed one, same remote as a few toyota trades around the same year that have come through my work.
Ill look again today and see if i can find the box. Im pretty good at wiring stuff up, but this one has be beat so far....
__________________
- Kyle
Former Owner of -
KyleT is offline
Old 02-21-2006, 10:33 AM   #7 (permalink)
If it is the factory alarm it should be under the driver's seat because that is where the factory harness hookups are.
You can remove by reversing the install process (but you can't just have auto locks and no alarm):
http://www.4runners.org/images/rs300...%20Install.pdf
__________________
- Jamie
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
2007 Tacoma Dealer Alarm itsmeagain5789 03+ 4Runner/GX470, & 05+ Tacomas 1 03-12-2007 05:38 PM
Ignition cutoff not working. deathrunner Alarm Systems 3 05-12-2006 09:01 PM
Starter/Ignition Problem 90 4Runner jm47 86-95 Trucks & 4Runners 5 02-07-2006 08:23 PM
Remote Starter...Ignition Override tarheelrunner 95.5-2004 Tacomas & 96-2002 4Runners 23 01-08-2005 09:01 AM
I Need Diagnosis Help: Ignition? Starter? hhinojosa Maintenance & Repair Archives 4 11-22-2004 03:24 PM
2009 InternetBrands, Inc.
