Dealer doesn't know where this wire goes
Old 06-11-2003, 05:33 PM
Chanson88's Avatar
Question Dealer doesn't know where this wire goes
My alternator belt broke on my 94 pickup with a 22 re and no air conditioning and knocked this wire loose, from the attatched photo, the wire is black with a white stripe and in a black sleeve. it splits off the main wiring harness that passes the under engine fuse box at the far right of the photo, and I can't find where it plugs in. I looked at wiring diagrams in a maintenance manual but couldn't find it. I went down to the dealership and they looked at it and then looked at their manuals and told me they didn't know where it goes, so if anybody out there has a similar year pickup or 4runner and could check to see if they can find the wire and where it goes, and if you need any more pictures or information from me let me know, thanks for the help.
Old 06-11-2003, 05:36 PM
wimpywade94's Avatar
ill look tonight but i dont remember that wire for anything.
ill look and get back to you. does the truck still work with it off??
laterz
wade
Old 06-11-2003, 05:38 PM
Chanson88's Avatar
Oh yeah, I forgot to say that the truck still works but it seems to run a little hotter, but that may just be me.
Old 06-11-2003, 05:46 PM
Gadget's Avatar
Does you low oil pressure warning light and gauge work?
Gadget
www.GadgetOnline.com
Old 06-11-2003, 06:02 PM
Chanson88's Avatar
yeah the oil pressure gauge works, and there are no warning lights on the dash.
Old 06-11-2003, 06:37 PM
92 Toyota's Avatar
Is that blue thing the oil filter?If so look under it(filter) my 92 22re has some kind of wire under the filter that plugs into the engine block,I don't know what it is but it looks like the same wire.only mine is yellow with blue stripe.
Old 06-11-2003, 06:40 PM
Chanson88's Avatar
I just checked and the wire isn't long enough to get to the oil filter and there isn't anywher I can see under it for a wire to go in, thanks for the idea.
Old 06-11-2003, 09:22 PM
david in germany's Avatar
you said you do not have ac?
thn that may be the ac compressor turn on lead (it is usaly just taped to the wireing harness.
David
Sleaker
08-26-2020 06:03 AM
Colington
03-08-2020 09:51 AM
smiley52
07-11-2015 05:16 AM
nick b
07-11-2015 04:38 AM
colinmil
07-06-2015 04:03 PM
Quick Reply: Dealer doesn't know where this wire goes
