Daystar lift vs. Revtek lift
Old 02-18-2004, 06:51 PM
Daddyape's Avatar
Is their anybody that can tell me their thoughts on these two lifts the Daystar 2 1/2in & the Revtek 3in (pros & cons)? I would also like to know if it would be safe to combine one of these lifts with the Battlez 2in spring kit to give it a 4 1/2 to 5 in lift? Thanks
Old 02-18-2004, 06:54 PM
Senior Member
data's Avatar
What yr vehicle is this going on? 4" to 5" = no more cv's. 3" with a diff drop would be the max you could go. That is more than enough to clear 285/75/16's. Personally I would go Revtek....
Daddyape's Avatar
My vehicle info
Sorry, I forgot to give my vehicle info. I have a 97 4Runner Limited. Thanks again!
Old 02-18-2004, 07:50 PM
Away
Dr. Zhivago's Avatar
Check out this thread on lift options for our trucks: https://www.yotatech.com/forums/f2/lift-questions-what-get-26927/
There are links in my post to other threads that answer a lot of questions. The most lift you can safely get on your truck, without doing a LOT of fabrication, is 2.5". The Revtek lift pushes the limits of the CV joints.
Hope this helps.
G
suppra87
07-15-2021 05:15 PM
1uzRunner
63
11-10-2018 03:58 PM
AkitaDog
09-03-2015 09:01 PM
matthew138
09-03-2015 08:21 AM
Ryall
09-02-2015 06:48 AM
Quick Reply: Daystar lift vs. Revtek lift
