Dark grey sludge under the oil cap...
Old 03-05-2005, 07:03 AM
Ontario's Avatar
I noticed this dark grey sludge under the oil cap. What is this? Should I be concerned? I live in Canada so Seafoam will be next to impossible to get... what else can I use?
Old 03-05-2005, 07:04 AM
Astralplane's Avatar
How's your radiator fluid level, had to add any lately?
Old 03-05-2005, 07:08 AM
Ontario's Avatar
Rad Fluid seems to be fine. I haven't had to add any more coolant... but I think I know where you are going with this... I can feel my wallet getting lighter.
Old 03-05-2005, 07:12 AM
Blair's Avatar
Hey Ontario,
You can get the magic elixer at Carquest. At least, I did at the one in Ajax.
Where in this country-sized province are you? If you're anywhere local (Southern Ontario- from GTA to the Kawatha's), I'll pick some up for you.
PS: What you're seeing on the fill cap is probably just condensation, from the not-so-nice temps we're enjoying lately. However, you may want to check and see if you're elligible for that free head gasket job.
Old 03-05-2005, 07:14 AM
It's definitely not that type of excess moisture then.
Excessive short trips in a cold climate?
Old 03-05-2005, 07:23 AM
Ontario's Avatar
I'm on London but I often make trips up to Toronto - I may be making a trip to Ajax.
I'm calling Toyota right now to check about this gasket maintenance bulletin.
Thanks Blair.
Thanks all.
Old 03-05-2005, 07:25 AM
Blair's Avatar
Good call...
The campaign is called 802 in Canada and you'll find Carquest on Bayley St West, Ajax. Stop by the firehall if you're in town.
Old 03-05-2005, 07:26 AM
Ontario's Avatar
You guys are good... yeah Astralplane, majority of trips are fairly short commutes and right now the temps are fairly low.
Old 03-05-2005, 07:42 AM
Ontario's Avatar
Called Toyota. Gasket was serviced/replaced in 1999.
the1998sr5
27
11-17-2015 09:30 AM
Yota.Jay
28
10-22-2015 01:08 PM
TDonkey
07-26-2015 10:14 AM
boogiewoogie
07-24-2015 05:10 AM
Quick Reply: Dark grey sludge under the oil cap...
