Damaged CAT
Old 01-06-2005, 12:33 PM
obxfishn's Avatar
Damaged CAT
While hunting I went off road and my CAT was damaged to where it cracked and is now leaking . Would an aftermarket CAT work or should I go to the STEALERSHIP and spend $500+ dollars for a new one. If an aftermarket CAT would do then who would you recommend??? Someone told me that the OEM's are the only one that would work properly with the computer configs and all. True or False?
Old 01-06-2005, 12:46 PM
MonsterMaxx's Avatar
get a replacement from summit for ~$100
do the labor yourself
Old 01-06-2005, 03:04 PM
PirateFins's Avatar
Go to NAPA and pick up a bolt on direct fit. $124 for me and it works fine.
Old 01-06-2005, 03:51 PM
bike4miles's Avatar
You can get a hi-flow knock off for $150. I don't think there is any compelling reason to get an origonal replacement.
I8URSVT
06-21-2016 01:31 PM
Dale Johnston
11
10-31-2015 10:22 PM
dzldust
7
10-06-2015 05:39 AM
voiddweller
09-28-2015 11:21 PM
Keithstoyota
09-27-2015 07:29 AM
Quick Reply: Damaged CAT
