cylinder two missin
Old 06-25-2010, 11:40 AM
billkmiami's Avatar
cylinder two missin
my 2000 taco 2.7 4 banger's cyclinder two is missing- threw a P0302 code- what do you think is burnt? Spark plug and wire seem fine??
thanks
Old 06-25-2010, 11:58 AM
snobdds's Avatar
How do you know your spark plug and wires look fine? Have you pulled your plugs and looked at them? How many miles are on the wires? Have you check the resistance on the wires?
You need to eliminate the simple stuff before you can go to other items
Old 06-25-2010, 12:02 PM
billkmiami's Avatar
how do i check resistance on the wire in question? I pulled the spark plug and it looked fine- can i trade coil packs? (switch them?)
Old 06-25-2010, 12:13 PM
snobdds's Avatar
I forgot the 2.7 has coil packs - my bad. You will have to search for the FSM on here for your specific year and it will tell you how to check the resistance on the coil packs with an ohm meter.
It will also give you some trouble shooting tips for the code your getting.
Old 06-25-2010, 02:18 PM
billkmiami's Avatar
just replaced all four spark plugs and installed new blue silicone ngk wires and it runs perfect! the blue wires look good under the hood!
4.34runner88
02-07-2016 02:24 AM
Obmi
11-24-2015 11:37 AM
Obmi
10-30-2015 04:27 PM
eggens
10-27-2015 03:14 PM
Squigglez
09-04-2015 07:33 AM
Quick Reply: cylinder two missin
