cylinder 4 misfire
Old 02-20-2008, 04:48 AM
Jcod12's Avatar
cylinder 4 misfire
about 2 minutes after startup my 4runner starts to misfire causing bad jerking, even when idling. acceleration is rough and the code i pulled is cylinder 4 misfire. i've cleaned the MAF sensor, replaced spark plugs, and i'm wondering what my next step should be.
- Jason
Old 02-20-2008, 06:42 AM
MTL_4runner's Avatar
Next step is to replace the plug wires. Finally if that doesn't help, you'll need to look at the fuel injector and be sure you have proper compression in that cylinder (ie compression test).
Old 02-21-2008, 02:29 PM
gah171's Avatar
cyl 4 misfire
I had same problem. mine was cyl 2 misfire- check out my thread. my problem was dirty fuel injectors.
shooter86314
01-07-2016 07:05 AM
Obmi
11-24-2015 11:37 AM
calderp
11-16-2015 02:49 AM
eggens
10-27-2015 03:14 PM
larrys93pickup
09-17-2015 07:05 PM
Quick Reply: cylinder 4 misfire
