Cyl 2 and Cyl 3 misfire, not P0420 - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Sign in using an external account
Register Forgot Password?
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 02-01-2012, 12:29 PM   #1 (permalink)
Personal Sales Rating: (0)
gdstock's Avatar
Cyl 2 and Cyl 3 misfire, now P0420
For the last week to ten days, I have been getting a cyl 2 and cyl 3 misfire. Cyl 3 was pretty random, the cyl 2 showed up as I was climbing hill at highway speed.
So over the weekend, I replaced plugs with NGK dual ground (had single ground installed), checked coils (all 3 ohmed out correctly) and marked coils and reinstalled in different positions to see if problem moved. Plugs and wires had about 8000 miles on them.
I was also getting a constant P0125 - Insufficient Coolant Temp for Closed Loop Fuel Control for a long time. After replacing both temp sensors, my son told me this was actually a O2 sensor problem. So I picked up a Denso O2 sensor to replace the cheap aftermarket O2 sensor I installed about a year ago (just before this code started showing up). I spilced this O2 sensor in as I could not reach connector. Thanks to research here, I found that the connector is nicely concealed beneath shifter boot (wtf?) and was able to plug the new one in correctly.
Plug 3 had broken porcelain at electrode.
Went on business trip Sunday and got back late last night, and did not experience any misfire codes showing up and the P0125 went away.
But on the way back I did get a P0420 Catalyst Syetem Efficiency Below Threshold. I plugged in scanner and plotted the O2 sensors. MOST of the time, upstream was reading higher than downstream, but ther were times when downstream value was very close, and occasionally at or above the value of the upstream sensor.
I banged on cat and it does not have a rattle to it. It does not run like the cat is clogged. NO loss of power, ideles and accellerates good. Truck has 270,000 miles and only one previous owner (my dad) and I do not know if he ever had cat changed. I have owned the truck for 7 years.
Before I drop the cash for a new cat, is this typical symptoms of a failing cat on these trucks? I know on a Dodge Ram, the typcial faiulure is for cat to clog up.
Thanks.
__________________
1996 Tacoma, 4x4, ext cab, 3.4L, 275,000 miles.
gdstock is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 02-02-2012, 05:29 AM   #2 (permalink)
revenantdead's Avatar
facebook.com/revenantdead revenantdead
check the fuel injectors. if you have one of the injectors stuck open it'll do some weird stuff.
__________________
'97 4Runner SR5 5vz-fe
K&N, Spectre modular intake (ISR), ARB bumper, IPF 868's, Hella 500's overhead, OME 3" lift, 31" Definity Dakotas, Hayden trans cooler, Flowmaster Exhaust, Yakima Loadwarrior w/extension, Cargo carpet delete, Cobra 19 ultraIII in-dash, Taco balljoint mod. i really need to bolt in my 1st gen rollbar.
Quote:
Originally Posted by waskillywabbit View Post
WD40. Hit it with your purse. Repeat.
Quote:
Originally Posted by xxxtreme22r View Post
Mine does this too, when it does I just hit it with my purse and wd-40.
revenantdead is offline
Yotatech
4WD Truck
Paid Advertisement
Tags
freeway, hill, misfire, p0420, sensor, speed
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Contact Us - YotaTech - Archive - Top
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
2010 InternetBrands, Inc.
