CV's, Wheel bearings, or something else? Help!
So here goes. I have a 97 SR-5 5spd and recently noticed my CV clamps loose and the inner boot on the driver side leaking grease. Not a ton but, some. Decided to pull and rebuild the OEM rather than throw on my Napa that's been laying around as a trail spare.
Everything went very smoothly, no issues until I went to test drive it around the block. Made it a couple of minutes away when all of a sudden heard/felt a pop and grind sound for about 5-10 seconds (basically until I came to a stop.) Actually sounded like something dragging more than anything. Looked at everything, nothing looked/smelled out of the ordinary.
Made it back home with no repeat of sound, decided to investigate further and pulled the CV again. Even decided to swap for the NAPA that was still new sealed in box. Tightened everything down after the swap and went to test it out. Same result, a few miles down the road with no issue and out of nowhere a pop/grid sound, stopped and checked before heading home.
I am at a loss as to what the issue is. No noticeable play in the wheel bearing. All ball joints and tie Rod's are new. The CV was fully seated with the snap ring popping into place during the swap. I just recently did the passenger CV about a month ago with zero issues. Any thoughts or ideas would be much appreciated.
Staff
I dont have much experience on your year of truck but I have had U-joints give me all kinds of headaches in the past that made me think it was everything else but the U-joints.
Whitemoneypit
20
11-01-2015 10:20 AM
83
11
10-19-2015 04:57 AM
FS[SouthCent]: TX - 4Crawler Ball Joint spacers
crash813
09-27-2015 07:15 AM
