cv axle without a snap ring?
I just changed a driver side cv axle, I messed up the snap ring and made it too large. I figure I'd never get it off again if I tried using it this way. Has anyone ever ran one without a snap ring?
After reading your message I was able to ascertain your problem immediately. Being an Auburn grad you should have stuck to a mule or other suitable beast of burden with adequate intelligence to help you overcome that Auburn education. Roll Tide!!!
Seriously. Do not run without the snap ring. I just went through the same issue where a buddy of mine (Vols grad - go figure) "helped" me get the snap ring off. It's a $.99 item at the dealer and they probably won't have it in stock.
Well I thought about it and there's not much travel in the front and I think the axle is long enough to keep it in.
The problem is that you don't have to pull the shaft all the way out to cause problems. If the wheel drops enough to pull the shaft out past the splines the you will cause damage. This is a $.99 part at the dealer and thy will have it in 2 days
polo451
13
11-20-2016 07:49 PM
Jcrawl94
10
10-24-2015 04:34 PM
