cruse control 2nd gen
Old 07-30-2003, 08:12 PM
my cruse control doesnt work, the button to turn it on works and i hit the set and accle and it still doesnt work. I have no idea where the fuse for the unit would be but it does not seem to be getting any power when i turn the circut on and my uncle told me he used it when he drove it home from the auction. Anyone else have the same problem or any ideas?
Old 07-30-2003, 08:22 PM
Robinhood150's Avatar
Try to pull the trouble codes and see if that tells you anything. Any chiltons or the FSM will tell you how to do it. My cruise went out after I got it wet and the dashlight flashed at me. I did pull the codes, but the cruise eventually dried out and fixed itself.
Old 07-30-2003, 08:23 PM
kaiberg's Avatar
something funny with my cruise too...turns on and works fine...but if i set it over about 60mph...which is always...it always wants to downshift out of overdrive...making the RPM's fly up to about 4300...any body got any ideas ?
Old 07-31-2003, 05:22 AM
Cebby's Avatar
That's normal for the 3.0 V6 equipped. My advice: Don't use the cruiise. Your right foot modulates the accelerator much better than the cruise.
Old 07-31-2003, 07:01 AM
Blair's Avatar
mterrizzi ...try this...
After you hit the cruise button, hit the DECEL button first.
I had a similar problem and this worked for me, for some odd reason. I checked the owner's manual and it doesn't mention this step, but like I said, "It worked for me"!
Old 07-31-2003, 03:02 PM
95_4X4Runner's Avatar
I had to adjust the cruise control throttle cable to remove the slack from it, and it works much better.
Just loosened the bolts, and positioned the cable housing further away from the linkage by loosening the rear nut, and securing it with the front.
Old 07-31-2003, 04:06 PM
Paul H.'s Avatar
I never use my cruise control. Don't like the way it shifts so much.
Old 07-31-2003, 06:36 PM
L33T35T 4Runner's Avatar
Re: mterrizzi ...try this...
mine has never done that. i love my cruise
there is no DECEL button
Old 07-31-2003, 06:57 PM
kaiberg's Avatar
thanks rob...good input...i went out right away and took a 12mm open end to it...ill see in the morning when i get on the freeway to go to work if it can hold steady at 70mph...
Old 07-31-2003, 07:11 PM
4x4CPOSEADOG's Avatar
Posted by Paul H.
I hate my cruise control. I don't use it much because it shifts so much. The last time I used it, I set it to 65 MPH at it shifted from 2500 to 4200 RPM and made my automatic transmission leak out, the oil temp light came on. I pulled over and let it run in park to cool the tranny. When I got home, I inspected and cleaned the underside with brake cleaner because the transfercase's skid plate, rear drive shaft, rear diff and axle were saturated with transmission fluid. That's how bad the leak was. Once the underside was cleaned with the brake cleaner, I had a hard time finding the leak. Don't know where it is coming from. I suspected that the transmission was overfilled with fluids and when it overheated it came out of the vent. Well, I will have to drop the pan and do a thorough inspection.
Noel
Old 07-31-2003, 07:36 PM
stretch786's Avatar
My cruise did something funny today...no matter the speed i was traveling the cruise would not set. I press set then the cruise light would flash. After numerous try it finally set. Weird
Old 07-31-2003, 07:46 PM
Blair's Avatar
L33T35T 4Runner...
...You're right...no "DECEL".
It's called "COAST". Pushing it MAKES you DECEL
Anyway, I just turn cruise on, hit COAST and then ACCEL button (Uh, I hope that's not called the SPEED UP button) and then it works fine. Doesn't work if I hit ACCEL first.
I commute 120 miles round trip 14 times a month on a two-lane highway and I use cruise all the time. Better mileage and more people get to see my Fedora, as they pass me
Old 07-31-2003, 07:55 PM
yes, to use the crusie control first you have to push the set button (bottom button) then if you wish to accel, puch the top button. also, if you push on the brakes or hit the cancel button, but stay above 35, you can hit the top button (resume/accel) and it will go back to the speed where you were at before, slowly though
Old 04-20-2007, 07:45 AM
GA95Runner's Avatar
how hard is it to REMOVE the cruise control completely?
Old 04-20-2007, 07:55 AM
mt_goat's Avatar
Boy... you dug deep to find this thread. You mean just the actuator? Or do you want to remove the contols from the steering wheel too? The actuator is just held on with 3 bolts, just disconnect the wiring plugs going to it and unhook the cable at the throttle body and remove it. Oh and plug the vac line too.
This may help:
http://personal.utulsa.edu/~nathan-b...10cruiseco.pdf
Old 04-20-2007, 08:05 AM
GA95Runner's Avatar
thanks!
and i just wanted to rid of the actuator.
Old 05-01-2007, 12:21 PM
KevinInSac's Avatar
The cruise buttons on my P/U are a little worn out. I figured out the main switch, and the PDF^^ Doesn't really show me the details of the the right side switches. Could somebody either show me a pic or describe them please?
Rasteirinho
11-06-2017 03:40 AM
rocket
01-21-2016 05:03 PM
JAMGarcia
7
07-31-2015 11:46 PM
vanion2
07-29-2015 06:17 PM
Steezy96yota
07-06-2015 10:00 AM
Quick Reply: cruse control 2nd gen
