Crickets under the hood??
Hey guys,
I have this weird noise coming from the engine bay and I can't figure out what it is. It literally sounds like a cricket is under the hood chirping. Its not belts I'm sure. When I accelerate I hear it but it comes and goes with acceleration.
Could a vacuum leak or air intake leak cause this kind of sound? I'm also thinking of replacing the PCV since its been a few years. I don't know if any of these things would cause this type of noise though...
I'd appreciate any suggestions or tips. Check my sig for specs on the truck..
Thanks, Kyle
Thanks, Kyle
Yeah, the belts were replaced last month. I suppose I could check the tightness of them but thats why I replaced them...cause they were squeaking or so I thought.
Its not like a squeaking noise....its almost like a chattering whistling noise.
I know these 2.7Ls are due for valve jobs once at the higher mileage but all that appears to be normal. There is no abnormal ticking or anything like that. Nor is there a rough idle or codes being thrown.
I have the same problem but with my 5speed 4Runner, but you have auto transmission right?. theres some linkage between the clutch and the transmission thats out of grease. if i lightly push clutch pedal, it gose away. some ppl say its throw out bearing too. ive put 40k miles sine the "chirp" and no problems, just that noise. you will also find more info about this subject if you search too. if you have an auto like your sig line, i dont know what to tell you.
Yeah that sounds about right...it sounds like its coming from the throttle body...but what would cause it other than a leak? I am going to replace the pcv valve to see if that makes a difference.
i was thinking it was the air flow around the butterfly. I also started hearing it after i did the deckplate mod. can you get it to make the noise if you play with the throttle when your driving?
Yeah man, I think you hit it on the head.
If I give it gas almost anywhere during the driving range, I hear it. I don't know if there is a fix for it or not. Do you have the 2.7L? Do you think its literally from the butterfly valve or its an actual leak around it? The funny thing is I've noticed it happening since I cleaned the throttle body a week or two ago. Perhaps there was carbon buildup that helped to seal it better. If thats the case, I'd probably just have to replace the valve (if you even can) or more than likely just replace the TB itself to get rid of the noise. Although, it may not be worth it as long as I'm not loosing performance or MPG from it...
i have the 3.4, but never thought much of the noise until this thread. but now that you mention it i have noticed the noise after i cleaned my throtle body to about 3 months ago. i dont know if its a leak or what. im cerious now to. my TB was dirty for so long the butterfly wore into the side of the TB and like used the dirt and such as sand paper, so now i constantly have a high idle unless i blurp the throtle to get it to close all the way. so i think im gonna replace the TB and see what comes of that noise.
coo man...please definitely let me know what kind of results you get.
I replaced the PCV today with no improvement...
Again, I still don't notice much in the way of performance loss...or so I don't think...
After doing some more poking around today...i think my sound is coming from the silencer on the intake system. Which would make sense as to why I'm hearing the noise now after a throttle body cleaning as I may have very well cracked some of the piping or a seal broke loose. More in depth diagnosis to come.
ashamsuddin
17
01-13-2023 03:17 AM
kawazx636
10-06-2021 03:03 PM
TheBFA
02-15-2020 06:55 AM
