Crickets in my clutch
Old 09-04-2003, 11:26 AM
Bob_98SR5's Avatar
Guys,
Very odd sound coming from the engine bay somewhere. I was waiting in the drive thru, put the 5-speed in neutral, and let my food completely off the clutch. And then i hear this sound that can be best described as "crickets". I barely put any pressure on the clutch and the cricket sound is gone.
Any clue?
Bob
Old 09-04-2003, 11:28 AM
TStango's Avatar
Throw out bearing? anyone else?
Old 09-04-2003, 11:29 AM
Fink's Avatar
Well your first mistake is putting your FOOD on the pedal in the first place!!!
Fink
Old 09-04-2003, 12:09 PM
SLC Punk's Avatar
Re: Crickets in my clutch
Originally posted by Bob_98SR5
Guys,
Any clue?
Bob
That's the exact same thing my dad's 96 5-speed does. He bought his new and its been doing that since 65,000 miles, he now has 120,000 miles and it runs fine.
I think its caused by the throwout bearing. I wouldn't get it done until you need a new clutch.
Its an annoying sound, but with your sound insulation project done, just roll up your windows.
Old 09-04-2003, 12:13 PM
rimpainter.com's Avatar
My 96 makes a quiet "turbine" type sound. When the clutch is depressed, it goes away.
Try spraying some Orkin in there and let me know if it goes away.
Old 09-04-2003, 12:35 PM
keisur's Avatar
Fink
yes, that usually attracts crickets.
Old 09-04-2003, 12:37 PM
SLC Punk's Avatar
I have a couple of tree frogs that you can borrow.
Old 09-04-2003, 12:39 PM
Bob_98SR5's Avatar
guys,
thanks for the advice re throwout bearing and pesticides.
where can i buy some cricket pesticide? will it hurt my MAF in the process if i spray too much? WILL IT INCREASE HORSEPOWER?!!!?
j/k
Bob
Old 09-04-2003, 12:53 PM
AznSky's Avatar
[B]WILL IT INCREASE HORSEPOWER?!!!?
YES!!!!!!!
but only if you're asian -_-
Old 09-04-2003, 12:59 PM
SLC Punk's Avatar
Originally posted by Toyo_Runner96
YES!!!!!!!
Sweet, in that case I am covered!!
Me too.
Old 09-04-2003, 01:21 PM
keisur's Avatar
if it's any consulation bobby, my toss off bearing has been cricketing for about a year now and the clutch is still strong. it's the original stock one. I used to squirt white lithium grease in the inspection hole where the fork comes out but I got tired of doing that every couple months so I just live with it. I figure when I replace the clutch that will get fixed but it's not worth tearing it down since the clutch is still real strong. it won't hurt anything.
Old 09-04-2003, 01:32 PM
Bob_98SR5's Avatar
Keisur,
Good to know, thanks. Do you have a pic of the above quote? I may try that.
Bob
Old 09-04-2003, 01:39 PM
keisur's Avatar
Keisur,
Bob
when I get home tonight I'll post a pic of it. you shouldn't miss it though. it's hole in the bell housing that the clutch fork goes through, the slave cylinder pressed on the fork on the outside and it pivots and disengages the clutch. there is a rubber cover that covers the gap betweent the bell housing and the back of the clutch fork. you pull this out and slide it out the fork and little and you can use the red straw to aim the white lithium grease spray at the center where the bearing sits. just make sure you use electrical tape to secure the red straw to the can so it doesn't shoot off into the bell housing. that happened to me but I figure it either melted away or it just got pinched and ground up. I guess I'll find out if I ever have to replace the clutch. haha.
Old 09-04-2003, 02:04 PM
Albuquerque Jim's Avatar
You could have a broken spring in the pressure plate?
Old 09-04-2003, 02:27 PM
AznSky's Avatar
Originally posted by <96 Runner>
Me too.
You're not asian!!
Old 09-04-2003, 02:54 PM
Tacoma Dude's Avatar
ah so grasshopper...
Asian is not by physical appearance but by state of mind.
Or so what my last fortune cookie said
I'm going out to buy pesticide for my extra power now
Old 09-04-2003, 02:59 PM
keisur's Avatar
Keisur,
Bob
as promised:
Old 09-04-2003, 03:01 PM
You're not asian!!
My aunt is Korean. Does that count?
Old 09-04-2003, 03:06 PM
Fink's Avatar
I like sushi...does that count?
Gimme some scotch tape(to slant my eyes) and a platter of Kung Pow Chicken and I'll be ready for Horsepower in a bottle...also known as Diazinon(sp?)
Fink
Quick Reply: Crickets in my clutch
