| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Crawler gears in a 3rd gen?
__________________
2000 4Runner Sport, 3.4L, 5 Speed, Custom Front Winch Bumper, Opened intake, K&N Airfilter, BFG A/T LT265/70R16, Bilstein Shocks, FreeFlow Exhaust, Poly Rack Mounts & Swaybar Mounts, Tundra TRDs up front and OME 891s out back. ToyTec Panhard Bar Drop. SS Front Diff Drop. Home-built 2x2 Sliders. ARB rear locker, OBA, CO2 See My 4Runner! |
#2 (permalink) | |
Quote:
You need a lefty transfercase. Its an early gear drive case modified to be driver drop. http://www.inchwormgear.com/store/pr...5c23ed0f4f6000
__________________
1987 Mutant 4runner|Slightly Modified|Lacking general build direction -Lifts and Tires look cool at the Mall, Lockers and Gears look cool on the trail. -Internet Nice Guy |
#3 (permalink) |
like stated its either lefty or duals
__________________
97 4runner, 2.7 5speed 4wd, 5.29, 33 horns armor locked lifted heavy SOB broken front and rear swaybars My Profile.. |
#4 (permalink) |
It sounds like the Lefty can't be shifted, 2 Hi to 4 Hi, while moving. Not good.
__________________
#5 (permalink) |
Staff
That would be because its a REAL tcase, some some mamby pamby chain drive.
No, it cannot be shifted from 2hi to 4hi over 5mph. The toyota gear driven cases are not syncro'd, so as to retain strength.
__________________
Tacoma miniheader install kit Now available! Click here for ordering information Need that hard to find part? Nix99 Used Toyota and Lexus parts! |
#6 (permalink) |
Not sure about the lefty. I have dual cases with 4.7 in the rear case, all gear drive, so I suppose I have real t-cases. I've shifted mine from 4hi to 2hi and from 2hi to 4hi at speeds up to 55mph many, many times.
Not sure why the lefty doesn't work the same way since it is essentially the same thing, with a different casing.
__________________
1987 Mutant 4runner|Slightly Modified|Lacking general build direction -Lifts and Tires look cool at the Mall, Lockers and Gears look cool on the trail. -Internet Nice Guy Last edited by AxleIke; 11-30-2008 at 04:29 PM. |
#7 (permalink) |
Staff
You have shifted from 2Hi to 4Hi? And you are sure you have gear drive cases? I have always experienced that the top shift gear drive can't be shifted from 2wd to 4wd when you are moving. I CAN however shift from 4wd to 2wd no problem at any speed.
__________________
#8 (permalink) |
I am 100% positive I have gear drive cases. I did my 4.7's myself. Lots of gears, no chains.
I can shift from 2hi to 4hi at any speed. Maybe we are discussing different procedures? I will detail my procedure with an example. I live in CO, so, if I'm going to take a drive to, say, the mountains, where snow is possible, I do the following: Go out to my truck, lock the hubs, get in the truck, drive to the mountains, if its snowy, I let off the gas so the truck is coasting, and pull the 4wd lever back into 4wd. The turbo truck will also do this with no problem. The 4runner is top shift, turbo is forward, both gear drive cases. The only possible way I can figure that this doesn't work for you is if you are referring to having the hubs unlocked. The chain drive cases have syncros so the ADD crap works. The transfer case speeds up the driveline, and therefore the diff, and then the vacuum stuff actuates, and the collar slides over and engages the front end. Gear drive trucks have to have the hubs locked. If you are driving straight, and the front wheels are spinning at the same speed as your rears, it should pop into 4wd no issue. The op just has to hack the add system so that it can be engaged manually when he is stopped, much like I lock my hubs. Then, if 4wd is needed out of the lefty, it will go in at any speed.
__________________
1987 Mutant 4runner|Slightly Modified|Lacking general build direction -Lifts and Tires look cool at the Mall, Lockers and Gears look cool on the trail. -Internet Nice Guy Last edited by AxleIke; 11-30-2008 at 10:58 PM. |
#9 (permalink) |
Staff
Hmm, that may be where the difference is Ike. I guess next time i will give it a try, and make sure the hubs are locked in.
__________________
#10 (permalink) |
locking the hubs is thee difference once the hubs are locked the front drive shaft will be spinning. This will eliminate the need to syncros. I change my FJ40 (gear t-case) in and out of 2h 4h and in and out of 2l and 4L at any speed the fj40 can reach.
__________________
69' FJ40 "RUSTY" H41,3 speed case, ARB Lockers F/R, 34x9.5 TSL's, Co2, Warn 5687, 2.5 " Parabolic lift, Pertronix Ingitor, 4+ U bolt flip kit, 20 gal. Aux Tank 2000 4-Runner SR5, V6, 5 speed, Highlander edition, S/C, URD 7th, DP TLCA #14752, L.A. Trail Crew Phi Kappa Psi http://www.marksoffroad.net My Parts Source |
#11 (permalink) | |
Quote:
I realized that you might be referring to the fact that Gerdo has ADD, and without a syncro case, would have issues shifting on the fly, since his driveshaft won't be spinning. Same as a manual hub truck with out the hubs locked in. Anyway, apologies if it came across snide. Wasn't my intention.
__________________
#12 (permalink) |
That is the cost of getting a stronger, more reliable Tcase. Gear driven cases are strong, and don't have a chain that can stretch and fail.
__________________
Scotty http://www.addictedoffroad.com/ 970-420-4198 Toyota Winch bumpers on SALE! |
#13 (permalink) |
If he hacks the add, he'll be able to. So, no real cost, except that you have to shift the add while stopped, same as a manual hub truck has to lock the hubs.
__________________
#14 (permalink) | |
Staff
Quote:
Its all good man!
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Marlin Crawler Gears | CTRJ | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 04-19-2007 04:35 AM |
| 3rd Gen speedo gears (transmission) | chadbobb | 95.5-2004 Tacomas & 96-2002 4Runners | 10 | 11-27-2006 06:40 AM |
| Ultimate Rock crawler 3rd gen | terryjmatthew | Off Topic Talk | 26 | 08-06-2006 06:08 AM |
| Marlin Crawler Ceramic Clutches & Tundra brake upgrade for 3rd gen P/U? | CoedNaked | 86-95 Trucks & 4Runners | 6 | 02-09-2006 07:37 PM |
| observations about tires/gears on my 3rd gen | jacksonpt | 95.5-2004 Tacomas & 96-2002 4Runners | 24 | 02-20-2005 06:12 AM |
