Crank pulley (Harmonic balancer) bolt hole for puller size?? - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 11-27-2007, 02:53 PM   #1
kcebes's Avatar
I have a harmonic balancer puller to try and get my crank pulley off. I'm in the middle of a timing belt change. The pulley won't come off freely. (Yes the 19mm bolt is removed lol) What size bolts do i need to attach the puller to the pulley? I've tried two kits and neither had the right threads! Help!!!
kcebes is offline   Reply With Quote
Old 11-27-2007, 03:08 PM   #2
kcebes's Avatar
UPDATE: A friend just got back to me and said it's either 8 or 10 x 1.25. Can anyone verify this? I think i have the 8's so maybe i'll just buy a few 10's.
Old 11-27-2007, 05:33 PM   #3
GSGALLANT's Avatar
They are 8mmx1.25. You'll need bolts long enough to reach the very back of the pulley, because only the rear part of the holes are 8mm and threaded (maybe the last 1/4" or 3/8" at the back of the holes). The front end of the holes are 10mm (or just under, because a 3/8" bolt fits in there) and are not threaded. The front part of the holes are used to insert the crank pulley holding tool, when removing or installing the crank bolt.
GSGALLANT is offline   Reply With Quote
Old 11-27-2007, 06:58 PM   #4
MTL_4runner's Avatar
Quote:
Ditto.....and hopefully they aren't rusted at all.
Put some antiseize on the crank nose when you go to reassemble.
MTL_4runner is offline   Reply With Quote
Old 11-28-2007, 04:41 AM   #5
kcebes's Avatar
Ugh...so i just didn't stick the bolts in far enough to find the threaded part! Thanks for the help!!!
Old 11-28-2007, 09:16 AM   #6
GSGALLANT's Avatar
Don't beat yourself up... it's a common mistake! Good luck with the rest of the job. Make sure you get the crank bolt torqued back up properly to 217 ft-lb (I also used blue loctite on the crank bolt threads to give me a bit more assurance that it won't back out). Take your time putting the belt back on and make sure you're timing marks are all lined up properly before closing everything back up. Other than that, you should be good to go.
HELP...94 4Runner Guy I bought it from lifted its Not so great. coffey50 Offroad Tech 17 07-28-2015 11:55 AM
22re electrical issue leaves me stranded in the Sierra v_man 86-95 Trucks & 4Runners 14 07-23-2015 05:01 PM
Screen size comparison dropzone GPS & Communication 0 07-16-2015 03:00 PM
Safari Rack Build, 89 4Runner HaydenConQueso The Fab Shop 0 07-12-2015 06:22 PM
Has anyone else ever had this problem? Badger62811 Off Topic Talk 2 07-05-2015 10:17 AM
Tags
1996, 2003, balancer, bolt, camry, crank, harmonic, haronic, load, pulley, rear, size, stick, tool, tundra
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
