| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Cost for retractable antenna
#2 (permalink) |
While I was at the dealership getting prices for the whip antenna mod, I asked about the price for the motorized antenna. If the motor still works, but the antenna fails to retract, then the plastic teeth on your antenna are most likely broken/damaged. My dealership was going to charge me about $35.00 CAD for just the motorized/retractable antenna. From some of the write ups I've been reading here, it may be as easy as pulling out the damaged antenna and feeding the new one into place. I'm not sure about cleaning the motor to remove the borken plastic bits though.
If you do decide to go the route of the whip antenna, I'm sure you will be very happy with it. I know I am! |
#3 (permalink) |
Most likely you can just replace the antenna mast (about ~$20 or so on eBay) and you'll be back in business. I had to do the same thing on my '01 as well because the mast broke due to AZ sun.
__________________
'01 4Runner SR5 - 4x4 - 1" lift PP springs, deckplate mod, amsoil air filter, optima battery, alum. skid plate, alum. tube steps - Pioneer 8500MP, PhoenixGold Amp + Infinity Kappas, RockfordFosgate Amp (mono) + Audobahn 10" Sub - Yakima roof rack, Silverstars, Black Pearl emblems, Wet Okole seat covers, Wood Trim - TRD Supercharger, 7th inj. kit... weee heee!!! |
#4 (permalink) |
If you're interested in checking to see if it's repairable yourself let me know. you'll need some tools and you'll get dirty(greasy).
__________________
Steve '96 4Runner < aw look, he wants his belly scratched |
#5 (permalink) |
I have the same problem with my 02 --- any enlightenment would be greatly appreciated!
#6 (permalink) |
you can get an aftermarket one at BestBuy for $50, and install would be anywhere form $32-$120 depending on the installer. It's not hard to install, just time consuming. Or, for the most part you can do what everyone else says, and replace the mast. I did this on my 99, and my sisters 01.
Brett
__________________
Current: 94 4Runner SR5 3.Slow...for now. SOLD. :( 99 4Runner Limited SuperCharged, Hood Scoop, Westin Bull Bar, PIAA 510's, PIAA GTX Heads and Fogs, ProComp 1069's, True Flow Intake, Jardine Exhaust, Red Interior Lights, Other Little Stuff... |
#7 (permalink) |
I replaced the ENTIRE thing in for like $30 from eBay and it only took about 90 minutes to install. And I have never done one before.
This included the mast, motor, wiring, etc. This is the best way to go IMHO. It will take you a little time just to figure out what to do... but it's worth it for $30. Good luck.
__________________
DON'T SHOOT! I'm an involuntary traitor to the Toyota world. This WAS my Toyota... a loaded 1998 4Runner SR5 2wd Check out my Sound Domain web page to see it in all it's glory! |
#8 (permalink) |
OK - so I found the replacement masts on ebay for $30 shipped. Is it just that simple to yank the old one out and put the new one in? Or do I go for the complete replacement for the motor and all?
I need to get the antenna fixed --- its really pissing me off!!! |
#9 (permalink) |
the antenna on my 4runner just makes a horrible grinding sound so i unpluged it and just pulled it up works fine
#10 (permalink) |
I can't believe you can only find the mast for $30 without the motor. I got the ENTIRE setup, antenna, mast, motor, etc for $30 shipped. It wasn't an OEM Toyota onem but it was made for a 4Runner. Keep searching... you will find one. I think it's better to replace the whole thing while you're at it. It was almost a waste for me... I have probably use the radio 2 times in the past 3 years since I installed it... but I at least have an antenna when I want one.
__________________
#11 (permalink) |
If it is still grinding while you turn the radio on there is no need for a new motor...imho. As stated the replacement can be done, it is time consuming, as you need to remove the underside of the fender flare (black plastic inside wheel well) if you cannot get the entire antenna up when you pull it out.
If it all comes up when you pull then you can just feed the new one back in, but you will need to measure the old versus the new to make sure you have all the teeth. If you don't have all the teeth, then you need to go in and get the rest (inside the wheel well). I have done it twice on the 4Runner (first one was faulty, and got a replacement due to one year warranty) and also did one on a Honda Accord of ours, all three in Jan./Feb. here in Central PA, very cold project. Both purchased on e-Bay for $20-$25. Note: When you pull the old one out, remember which way the teeth were headed to replace the new one. It is something you CAN do yourself, so I would say go for it....if all else fails yotatech is here and there is always a stealership that can help you out of some one $ if you get in a jam... Good luck!
__________________
- Jim 1997 Radiant Red 4-Runner SR5 4X4 3.4 L - Maglite mod. |
#12 (permalink) | |
Quote:
#13 (permalink) |
Cool - yeah, I figure the motor is still good - it still operates - it just won't retract - if I run around to the passenger side after I shut the engine off and push down on the mast, it will retract. I figure the teeth are stripped right at the full extension point. I'm kinda leary of a whole motor assmbly for $30 --- I would question the quality. Looks like the replacement mast is the way to go - dealer wanted ~$140 to replace the mast - $240 if they had to dig the strap out of the motor.
I'll risk the $30. Anyone reccoment which group to get it from on ebay? It looked like there were two places hawking masts. |
#14 (permalink) |
bridgewood_motorsports also go by AntennaMastsRUS
They were really nice to deal with, they also are the ones that helped me when the antenna needed replaced through warranty.
__________________
#15 (permalink) |
Hmmm... interesting.
Yes the motor still goes on when turning the radio on or off, but the mast does not retract. I will loosen the nut and see If I can pull out the broken mast. Again, many thanks for all the great replies! |
#16 (permalink) |
OK - ordered the mast from bridgewood. Was kinda bored so I went out to pull the old mast - came out really easy (yeah, REALLY greasy!), but I'm pretty sure there is a lenght of tooth cord left in there
Looks like I'm in for the hard route! I will do some searching to find out what its gonna take, if anyone can make easy for me, I'd appreciate it
#17 (permalink) |
Check out this post:
http://www.yotatech.com/showthread.php?t=76343 http://www.4runners.org/articles/whip/ It is for the Taco whip instal, but it gives you the idea on how to get there, just don't do the cutting suggested to remove the old one :pat:
__________________
#18 (permalink) |
Yeah, I found those already, but thanks
That gets me TO the motor, but I am wondering what its gonna take to get the strap out of the motor Will I have to remove the motor, or is there a side plate that comes off without dismounting the motor? I would prefer not having to dig in and remove the antenna wire to the radio. I guess I'll be finding out when the mast gets here ~thursday. Post up if anyone is interested in seeing any pics of what it takes. If people are interested, I'll go get a new bucket of gojo so I can take pics along the way --- I'm expecting its going to hella greasy judging by the gease just on the mast. For anyone that is curious, the teeth on the mast point FORWARD when inserting --- this is a hard thing to catch as you rip the mast out!! |
#19 (permalink) |
You will have to take it apart, I did it without removing the wires (I think). There are a few bolts to remove to open it up, but the majority of the unit is a housing to hold the coiled antenna teeth.
The toughest part, for me, was getting to it. once you are in there it all makes sense, really it does. Hopefully someone with some better insight can reassure you also, but I am not the most mechanical person and I got it done.
__________________
#20 (permalink) |
well i had the same problem. i ordered a new antenna from ebay. all you do is take the retaining nut off the antenna base. turn on the radio and pull out the old antenna mast. now i just took out what came out, if there were any residual pieces left, well they're still in there. just remember which way the teeth were facing when you pulled it out. when you get the new antenna, the plastic teeth are coiled up. you need to uncoil them and get them as straight as possible. now all you do is feed the theeth in stil it catches the gears, and you turn off the radio to retract the antenna, you may have to do it a couple of time be fore it goes in right. but mines in and it works great.
__________________
김치 '96 4runner limited, 265/75/16 yokohama geolander at, duplicolor painted factory wheels, and hopefully more to come. I will add pictures soon.켄니 |
#21 (permalink) |
I did mine last month. I have done many on a lot of different makes and models. I would always take the housing apart even if you were able to get the geared line out just to make sure that there isn't any crap in there, and also to re-lube everything up again, so that it doesn't break soon after you put the new one in.
#22 (permalink) |
The first time I had a broken antenna mast, I just replaced the mast and didn't open the housing, leaving the broken piece inside the housing. Worked great for about a month, then the broken bits worked themselves loose and started jamming up the works. Made a horrible grinding sound and the antenna stopped going all the way up. So then I had to start over and remove the broken part.
IMHO, I would have been better off just doing it right the first time by pulling the housing and taking out the broken pieces out. On my '99 4Runner there is one nut that attaches the antenna assembly inside the fender (plus the antenna nut on the top). Once you get the fender liner off (or pulled back enough to get your hand in there) just reach back and feel around for the nut. (10mm, I think). Remove this and the antenna nut and the housing comes right out. No need to disconnect the wires, just set it on top of your tire, remove the 5 (or 6) bolts that hold the cover plate on, fish out the broken bits, then reassemble. Very easy. Based on my prior experience I would be concerned that leaving the broken bits in the housing might jam up the electric motor and cause a more costly failure. Good luck- -Scubaduck |
#23 (permalink) |
i see you point there, i just hope mine works out with no problems.
__________________
#24 (permalink) | |
Quote:
"If you intend to possibly re-use the motor again, do not cut this wire (like I did). To remove it, continue reading below" bob |
#25 (permalink) |
Staff
My original motorized antenna on my '96 4runner STILL works fine but i'm replacing it with the Tacoma whip because i personally think a motorized antenna sucks wether it works or not. For one it's very annoying and for two it has the the potential to break.
Get yourself a Tacoma antenna assembly. PROBLEM SOLVED. Part number 86300-35090 $32.18 shipped from Northridge Toyota http://www.yotatech.com/showthread.p...1&page=1&pp=25
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 1st gen retractable rear seat belts | jakesooy | The Classifieds GraveYard | 1 | 07-03-2006 06:59 PM |
| Mobile video screens other than retractable indash... | Cebby | Vehicle Audio & Home Entertainment | 1 | 07-30-2004 03:24 PM |
| Power Antenna - Stuck Up and No Motor Sound and other Antenna Questions | PhxRunner | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 06-28-2004 03:37 PM |
