coolant level question
hey guys i just had my tbelt, waterpump and thermstat replaced by a local shop (close family friend) and when i got the truck back i noticed the coolant level in the resevior was low so i filled it back up to full.. well i got off work today and the level was inbetween low and full. i got home (35 miles later) and the coolant level is back up to full. is this normal? or does the system need to be burped? thanks guys
It`s a pressure system. It will, as you mentioned, burp itself if needed. When it gets hot it keeps more fluid under pressure in the system and when it cools, it will equalize itself thru the cooling process and re-fill the holding tank.
All should be well.
All should be well.
yeah thats what i plan on doing jamie.
has anyone noticed a better response throttle wise since having a t-belt change? call me weird lol. but with a 105k miles on the tbelt to a new one, i can tell a difference.. side question, do you guys reset the computer after a tbelt change?
the1998sr5
15
07-14-2020 08:35 PM
nframe
3.4 Swaps
08-16-2015 09:03 AM
itzmywife's
07-25-2015 04:55 PM
FS[NorAtl]: 05+ tacoma leveling lift front MA
akaphilly
07-09-2015 02:18 PM
Avenged
07-09-2015 07:55 AM
