Coolant leak, leaks when not running - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 02-16-2005, 11:53 AM   #1
i got home this morning from down below with my mom and when we pulled up i saw a puddle under my truck, great i thought. i pop the hood and i see coolant leaking from somewhere by the throttle body/upper rad. hose. I could see it just dripping and i havent driven it since the night before so why would it leak all of the sudden and not while im driving it? I just replaced both radiator hoses and the intake has all new felpro gaskets.
desert whomper is offline   Reply With Quote
Old 02-17-2005, 05:52 AM   #2
I had the exact same thing with my '88 22RE. I figured it was a head gasket gone bad. Didn't have any oil/water mixing problems going on, so I just added some Prestone Stop Leak to hold me over until I do a complete engine rebuild or replacement.
I think it leaks while not running because just sun light warming up the car expands the cooling fluid enough to send it out the leaky spot. Could be wrong, but in my case the Stop Leak did the trick for now.
88w/300K!!! is offline   Reply With Quote
Do I bother fixing it? 1993 3vz-E 4x4 Colington 86-95 Trucks & 4Runners 13 07-21-2015 06:24 PM
Leaking extention housing seal andrewtexas123 86-95 Trucks & 4Runners 3 07-14-2015 05:29 AM
3vze help nick b 86-95 Trucks & 4Runners 4 07-11-2015 05:38 AM
22r leaking 87blyota 86-95 Trucks & 4Runners 3 07-10-2015 05:31 AM
Radiator leak. Now where to? (2000 v6) Avenged 95.5-2004 Tacomas & 96-2002 4Runners 4 07-09-2015 08:55 AM
Tags
anitfreeze, coolant, engine, im, leak, leaking, leaks, off, radiator, running, stop, sudden, truck, turned, yotatech
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
