coolant flow issue after head gasket replacement
'97 4Runner - V6
Replaced the head gaskets after the original failed and started leaking coolant into the number 2 cylinder. All hoses, gaskets and water pump replaced. It appears that there is no flow of warmed coolant pass the thermostat. Checked the radiator and it has good flow. Thermostat checks out okay. Removed the thermostat and refilled... get good flow back to the radiator. Any thought's on what to try next? I'm thinking about removing the bypass hose from the water pump to see if coolant is flowing from the oil cooler out the side of the block. Vehicle runs perfect except for the overheating issue. In addition, when I open the heater valve wide open the truck runs in the normal range. I guess it's acting as my radiator at this point.
To be honest, I didn't run it long enough to determine if it stay cool with the thermostat removed. I will perform a more thorough test this evening. Definetly runs hot with a good thermostat installed. The key is that the warmed coolant never circulates past the thermostat, so in turn it does not open.
If omuddr took pictures during his install (which you should always do, by the way), it would allow us to verify that they are installed correctly and at least rule that out as a possibility.
yes the same is possible on the 3.4 you have to watch the coolant passage on the driver side head that drains right down on the thermostat. also the lettering on the 3.4 gaskets face down not up like the 3.0
zd92655
03-06-2022 12:58 PM
Team420
01-12-2021 04:57 PM
voiddweller
19
05-02-2016 09:10 PM
scotts93
07-18-2002 04:10 AM
22r, 34, 4runner, 97, coolant, direction, flow, gasket, head, problems, replacement, thermostat, thremostat, toyota, yotatech
