Coolant dripping from Exhaust Manifold??? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-03-2008, 08:52 PM   #1 (permalink)
So i have a good one for you guys... I was loosing coolant and had no idea where it was going... I thought it was a headgasket.. but 4runner seemed fine... oil checked out, temp is fine, plugs looked fine, exhaust smelled like coolant though, and fouled up my cat (p0420 CEL)... I look under my car, and see the exhaust manifold. I saw coolant leaking from the rear cylinder ON/IN the exhaust manifold... I looked at the bottom exhuast stud and it was not tight, it is actually stripped (not sealing manifold). Everywhere around the HG is clean, just coolant leaking out of the rear exhuast port/lower stud don't know how coolant got there since it's above the HG and valves??? Is someone playing a cruel joke on me??
I plan on pressure testing the coolant system tomorrow and probably doing a compression test just to make sure it's not a HG problem. And i'll actually pull the exhaust manifold off too to see exactly what's going on... Any other ideas??
1996 4runner 3RZFE 4x4 5spd
brylew is offline
Old 10-03-2008, 08:59 PM   #2 (permalink)
georgiayota's Avatar
could there be a crack in the head?
__________________
So much to do, yet so little money.
under construction:
82 Pickup still getting goodies
build up thread: http://www.yotatech.com/f114/my-82-b...thread-158522/
parents commuter:
07 Camry, K&N, tinted windows, 135,XXX miles
My other toys:
2008 Kawasaki KFX 450r, pro circuit exhaust, tusk black nerfs, tag black front bumper
2004 Suzuki Eiger 4x4, custom snorkels, 27 mudlites, warn 2500, uni filter
georgiayota is offline
Old 10-03-2008, 09:32 PM   #3 (permalink)
racermp's Avatar
take out the plugs to see which cylinder is letting in coolant. most likely, u need to do headgasket and prolly rebuild head/s.
__________________
96 4Runner SR5 2WD Auto
racermp is offline
Old 10-03-2008, 09:36 PM   #4 (permalink)
toytech76's Avatar
You could very possibly have porosity in that head. You will probably need to replace it. Pull it off and have it pressure tested
__________________
97 Runner. 4" Pro Comp IFS lift in the front, LC coils and shocks in the rear, 33x12.5/15 Pro Comp mud terrains, 15x8 Pro Comp 1069 alloys, 00 runner headlites, clear corners and bumper lenses, 00 runner airbox/MAF conversion, Reverse indiglo gauges, 5000K HID's, LC hood struts, Magnaflow exhaust, custom grill insert, hella driving lights converted into headlight highbeams, retrofitted avalon homelink sunvisor.
toytech76 is offline
Old 10-03-2008, 10:33 PM   #5 (permalink)
algranger's Avatar
sounds like maybe a cracked head.. ive never heard or porosity in a head but its always possible
__________________
I said lie, for me
lying under a process tree
algranger is offline
Old 10-04-2008, 02:41 PM   #6 (permalink)
Update
Took off exhaust manifold and saw coolant in the rear 2 exhaust ports Did a pressure test which confirmed a HG or cracked head... Won't know for sure til i get the mechanic to open it. It's gonna cost me 900 for a HG and valve job!!! So much for that new ijoy massage chair i wanted... Hopefully it's not a cracked head... Cuz then i mine as well start looking for a new motor... double
brylew is offline
Old 10-04-2008, 03:13 PM   #7 (permalink)
toytech76's Avatar
If its a bad head, you can get a brand new head with new vlaves and cam with a gasket set from attarco for $250. I have used one and know you cant beat it for the price
__________________
Old 10-05-2008, 01:15 PM   #8 (permalink)
jeremy9allen's Avatar
Quote:
Originally Posted by brylew View Post
So much for that new ijoy massage chair i wanted...(
No, but seriously... That does suck.
__________________
97 4runner SR5 Locked, Lift, Sliders, 33" Bighorns, 2 TRD stickers 5hp each= 10hp+
83 Toyota Pickup Shortbed 4x4 Lift, 33" BFG M/T, Lincoln Locker
jeremy9allen is offline
Tags
1992, coolant, corolla, dripping, exhaust, fluid, gallery, intake, leaking, manifold, porosity, radiator, rear, toyota, xxx
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
need help...broken nipple on TVV on coolant manifold on back of 3vze engine DCS 86-95 Trucks & 4Runners 5 09-19-2007 07:36 PM
3.0 Coolant Leak Under Intake Manifold Gurney Newbie Tech Section 9 06-09-2007 06:28 PM
22r coolant in exhaust (but not from 4 exhaust ports) riceburner 86-95 Trucks & 4Runners 5 05-07-2007 07:10 AM
The old coolant into the exhaust manifold trick phorunninduke 84-85 Trucks & 4Runners 0 09-14-2006 01:24 PM
22RE intake manifold coolant leak -Please help... 95g ATL 84-85 Trucks & 4Runners 3 05-02-2006 05:58 PM
2009 InternetBrands, Inc.
