Color of remote wire on factory head unit
Anybody know what the color of the remote wire on the back of the factory head unit is. Or does anyone have a diagram of the wiring harness. For some reason Toyota doesn't use standard color coding for their stereo equipment, making it really difficult to figure anything out. I appreciate the help.
-Ray
-Ray
-Ray
-Ray
T
Originally Posted by Duffdog
...how long have you been installing? no manufacturer has ever used MERA colors on any factory radio nor supplied a separate "remote" wire for use on an aftermarket amp. Youll have to use the ignition wire that goes into the deck-- in most toyotas its grey.--- what year make, model might help a little too since the colors change every body style and with some trim packages.
T
T
Originally Posted by Churnd
Either solid blue or blue with a white stripe.
I started this project yesterday. In order to run an aftermarket amp you have to tap into the speaker outputs and run a interface to convert get RCA outputs. I got the interface and located the speaker outputs which I will tap into this afternoon, when I get out of work. The problem I was having was figuring out which wire is the remote turnarournd which I need to tap into also. I do know of the grey wire and the blue w/ stripe. You say it is the blue w/ stripe that I tap into? Anyone done this that can give me a thumbs up to tap into this blue wire. Thanks
First off, its a '99 Tacoma.
Just found this: Toyota Radio Wiring. Maybe that'll help some. If the color still don't match up to the colors on that site, just compare them to the connector and find out which one you're looking for.
I wouldn't personally tap into that blue wire. That sounds like the antenna wire. Remember when hooking up an aftermarket amp, the wire they usually use for the remote is blue, but when you're tapping into a remote on a factory deck, that doesn't automatically mean it's blue as well. I'm thinking it's probably the grey wire (ignition wire) and not the blue. If you're installing an aftermarket amp, why don't you just run a seperate remote wire off the amp and tap into a fuse that comes on with the vehicle, such as the ignition fuse. I know it's not the ideal setup, but at least it would work.
Well I know that the grey wire is the ignition wire. So I take a remote wire from the aftermarket amp to the grey ignition wire right. Hmm, I think that is what i'm going to try this afternoon (crossing fingers). The rest I think I have figured out. If anyone has anything else to add I'm taking suggestios.
Thanks.
Thanks.
I had a post about this also, I had found a link somewhere that had all the colors and confirmed it with Crutchfield. I had a 97 4runner with the in dash 3cd changer with seperate amp. I cant find the link or my paperwork for some reason but I do believe it was a pink wire with a blue stripe. That was the remote for the factory amp and did not turn off if radio was off. Ill look and see if I can verify. The color may be different for you.
ok, I found my papers, it was a pink wire with a blue stripe on my toyota. I think I also found it by using this diagram, I think it was power antenna wire 2 that is the one that is used for amps and is not switched off when you play cd or tape. http://www.installdr.com/Harnesses/Toyota-Wiring.pdf
This one is also helpful but it doesnt show the colors just the location of the wires in the wireharness of 5 common toyota radios, then you can locate it and see what color it actually is. http://carstereohelp.net/wireharness_Toyota1.htm
Do we want to permanently post these sites? Maybe the moderator can do it for us?
Good luck!
Good luck!
Well I know that the grey wire is the ignition wire. So I take a remote wire from the aftermarket amp to the grey ignition wire right. Thanks.
{pardon the hijack}
Hey Ray...
Can you please read your private messages? There are a couple of people that have been trying to get ahold of you for a while now.
Thanks
Mark
Hey Ray...
Thanks
Mark
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
09-09-2015 06:24 AM
