cold weather first gear to second issues - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-14-2008, 05:03 AM   #1 (permalink)
foxxtrot's Avatar
When the weather drops below 36, I have issues with the switching of gears from 1st to 2nd???? What is the cause of this problem?
1)Do I need to let the car sit and warm up longer?
2)Do I need a tranny flush with new fluid?
3)Other?
Is there a winter weather tune up for a 02 Taco, manual tran, 4cyl?
foxxtrot is offline
Old 10-14-2008, 06:05 AM   #2 (permalink)
mkgarrison5's Avatar
we need details. mileage etc.... my guess would be that its just cold OR you have waited too long to do drain the gear oil out and put new gear oil in. usually its pretty thick (manual gear oil) when its cold and will thin when it gets warmer. it needs to be changed every 30k miles or less pending on how you drive
__________________
02 Tacoma 4-Dr 4x4 V6
117k miles
mkgarrison5 is offline
Old 10-14-2008, 08:07 AM   #3 (permalink)
birchy's Avatar
Mine does the same first thing in the morning before it gets warmed up. Doesn't shift from first to second until like 60km/hour.
I'm going to change the oil out ASAP.
__________________
4Runner is gone! :(
2000 Ford Expedition Eddie Bauer
1986 Volkswagen Jetta
birchy is offline
Old 10-14-2008, 09:02 AM   #4 (permalink)
In a manual I can understand it using the regular trans oil. I switched to Redline (MT-90) oil and it is a lot easier to shift in cold weather.
__________________
Carsten
99 4runner SR5 4x4 5spd
Roadtripr is offline
Old 10-14-2008, 09:28 AM   #5 (permalink)
keithguts's Avatar
Send a message via AIM to keithguts Send a message via MSN to keithguts Send a message via Yahoo to keithguts
I have a 1995 4runner 3.0, and it always did this since I got her. It just needs time to warm up, then she is fine. I was told that this was normal.
__________________
IF YOU DON'T DRIVE A TOYOTA, TEST DRIVE ONE TODAY!
MY PICS
95 4runner 3.0 auto 4x4
My Rig
My Rig
RangerMan
Enjoy
keithguts is offline
Old 10-14-2008, 04:52 PM   #6 (permalink)
littlerunner's Avatar
normal condition.but change to synthetic gear oil & it will be a lot better.maybe no problem at all
__________________
91 4runner,5spd,bone stock,rblt 3.0 @ 303,000 miles.OME 900 rear springs,front & rear shocks.97 runner wifeys
littlerunner is offline
Old 10-14-2008, 07:28 PM   #7 (permalink)
racermp's Avatar
tranny flush. usually when cold and late 1'st to second on pretty much all autos just means it needs a tranny oil change/flush. i did it on amy sisters 98 2.7, made it smooth again.
EDIT: nm just saw it was a manual ha
yea i noticed this on bimmers manuals too, fluid change on the bimmers helped that
__________________
96 4Runner SR5 2WD Auto
racermp is offline
Old 10-14-2008, 11:39 PM   #8 (permalink)
I recommend a good synthetic Manual Trans gear oil. This should give you smooth shifting in any weather.
Paul
__________________
Gone, but not forgotten:
1996 4X4 4Runner LTD. Purchased used 5-08, 120K. Now has 265/75 16 Terra Grapplers, Performance Products springs, Bilsteins. Cupholder Mod.
2001 Tundra, V8, 4x4, Xtra cab, Limited, TRD Offroad. PP springs, Bilsteins, Snugtop shell. Owned 0-112k mi.
1992 4Runner, V6, 4x4, 5spd, SR5, PP springs, Bilsteins. Owned 0-219k mi.
1988 Pickup Xtra cab, I4, 4x4, 5spd, SR5, Ranchos, rear shackles, shell. Owned 0-122k mi.
SoCalPaul is offline
Old 10-14-2008, 11:49 PM   #9 (permalink)
khoopes's Avatar
Double check the OEM recommendations but if it has 80/90W gear oil in it then it can be changed to any brand of fully synthetic 75/90 gear oil and your shift problem will likely disappear or greatly improve. The only reason you don't want to this sometimes is obviously if your tranny runs 30W oil or ATF in the manual trans like some of the fords did. (My Toyotas are old, don't know what your 02 has.) but the synthetic stuff is great year round unless you have leaks.
__________________
Kristopher Erik "KD5EJO"
Transplanted Alaskan in Foster OK
88 X-Cab now with 22RTE/93 FZJ80 Landcruiser w/e-lockers/"Work Truck" 00 Lexus LX470
FOR TOP NOTCH CARBURATOR OVERHAULS CLICK HERE http://www.yotatech.com/f37/ekhi-cus...turing-162085/
Like Fishing, hunting, Ham radio, flying, canoeing, kayaking, traveling, all the better with friends.
Dedicated Christian. Excellent Wife. 3 Very Good Sons. Any other questions?
khoopes is offline
Old 10-15-2008, 04:53 PM   #10 (permalink)
foxxtrot's Avatar
I am going to change the oil. I am currently at 95xxx miles so I am sure it is time.
foxxtrot is offline
Old 10-15-2008, 05:06 PM   #11 (permalink)
I used redline oil, and it did help. The shifting is a little easier and not as "notchy".
johnw999 is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Can cold weather kill your AC? UncleBob 86-95 Trucks & 4Runners 6 03-30-2007 10:10 AM
cold weather camping Riverboy Off Topic Talk 6 12-05-2006 06:13 AM
Finally some cold weather down here Jeffires Off Topic Talk 4 12-20-2004 11:21 AM
cold! cold! weather noise in front end jimber00 95.5-2004 Tacomas & 96-2002 4Runners 7 02-12-2003 09:25 AM
2009 InternetBrands, Inc.
