Cold air intake and inner fenders 2001 Taco
Old 06-26-2014, 02:04 AM
WpgWelder's Avatar
Question Cold air intake and inner fenders 2001 Taco
Hey guys/gals,
I have a 2001 Toyota Tacoma DLX model, 3.4L V6 Automatic.
I been getting alot of mud and water in my airbox and I noticed that the inner fenders don't really cover the Cold Air Intake tube.
Is there anyway to combat this? Seems kinda stupid that Toyota would put the air intake in the fender wells with nothing to protect the airbox from sucking in alot of crap.
I've heard of a "deck plate mod" and looked at aftermarket CAI's.
I use my truck mostly as a daily driver with the occasional muddy offroading next to a river to go fishing in hard to reach places.
Suggestions would be greatly appreciated as I'm getting tired of cleaning out my airbox of wet gravel/mud and drying out my filter.
Old 06-26-2014, 04:04 PM
rworegon's Avatar
A deck plate mod will make your situation worse with a 8-10cm (3-4") hole in the front of your airbox.
If you are going through water that deep, you may want to consider a snorkel for the airbox.
Old 06-26-2014, 04:17 PM
WpgWelder's Avatar
uhm i'm not going through deep water at all!!! and the mud is no more than a couple inches deep, but I have no inner fenders, so the water and mud go right into the intake tube and into the airbox.
Doesn't matter if i'm driving in the rain on the street or not, my airbox filter gets soaked.
I just figured the deck plate mod would be more likely to keep the airbox dry and i can seal off the oem intake tube.
Old 06-26-2014, 04:28 PM
rworegon's Avatar
Oh, I see...bad read on my part.
Well, the deck plate mod may help some if you use window screen to screen off the hole so small debris cannot enter the box. On the Tacoma, the box sits right behind a headlight and I'm able to leave it open year round without a deluge or water getting into the airbox.
Old 06-26-2014, 06:35 PM
busmup808's Avatar
You have mail
Sent from my MB865 using YotaTech
Old 06-26-2014, 07:32 PM
WpgWelder's Avatar
I should have mentioned I have 33x10.5R15's on my truck, so I can't run the plastic inner fenders without it rubbing anyways.
Thanks, that's what I figured. I've never had water higher than maybe hubs of the wheels, so deck plate mod with a screen on would probably be my best bet. Then it's just a matter of figuring out how to plug the oem intake tube in the fender or maybe just remove it.
Old 06-26-2014, 11:51 PM
250000_yota's Avatar
Do you have any sort if lift to clear the 33's? My little brothers tacoma clears 33's just fine off of a small Toytec spacer lift. Personally, I'd put the fender liners back in, and work to clear the tires. They're designed to prevent this exact situation.
Old 06-27-2014, 11:04 AM
WpgWelder's Avatar
i got a 2 inch lift in the back, but nothing in the front. This is he way I bought it in January. Just been dealing with the guys issues.
Old 06-27-2014, 11:38 AM
RAD4Runner's Avatar
Originally Posted by 250000_yota
... I'd put the fender liners back in, and work to clear the tires. They're designed to prevent this exact situation.
Exactly, Liners are supposed to keep dirt/mud/water/dust being stirred up by tires from the intake.
Old 07-06-2014, 07:17 AM
WpgWelder's Avatar
ok so i've got the hardware to install the liners, do the fender flares need to be removed in order to install these things?
Old 07-07-2014, 05:16 AM
KZN185W's Avatar
not familiar with Tacoma but in the 4Runner, you only need to compare the holes in the liner to the screw clips on the fender, no need to remove the fender flares
calderp
Engine Swaps
08-16-2016 05:15 PM
RatOmeter
10-22-2015 03:17 PM
Up&Down
08-11-2015 10:04 AM
calderp
07-27-2015 09:58 AM
mengquis
07-13-2015 10:39 AM
Quick Reply: Cold air intake and inner fenders 2001 Taco
