Cold air intake...
Old 07-08-2004, 01:14 PM
bawlinmo's Avatar
Exclamation Cold air intake...
"THIS AIR INTAKE SYSTEM WILL FIT ON 95-99 TACOMA / 4RUNNER 2.7L 4CYL ENGINE. THE AIR INTAKE PIPING IS MADE BY T-306 ALUMINUM, IT ADDS AT LEAST 5-10 HP AND 12 -16 HP TO YOUR CURRENT PERFORMANCE WHILE ADDS COOLING EDGE TO YOUR CAR. THE CONE FILTER IS MADE BY HIGH QUALITY MATERIAL, IT'S WASHABLE AND REUSABLE. THE AIR INTAKE SYSTEM IS DESIGNED TO INCREASE HORSEPOWER, GAS MILEAGE AND MASSIVE AIRFLOW, QUICKER THROTTLE RESPONSE AND MOWER POWER THROUGHOUT THE RPM RANGE. IT'S ABSOLUTELY THE NEXT GENERATION FOR THOSE INSPIRED OFF-ROAD. YOU JUST HAVE TO GET ONE FOR OUR CAR. THE ITEM IS MADE BY GOOD MATERIAL, NOT LIKE THE OTHER CHEAP INTAKES!! NO INSTRUCTIONS INCLUDED, AND PROFESSIONAL INSTALLATION RECOMMENDED."
__________________________________________________ _______--
So Im wondering....is this stuff not good? I notice everyone cutting holes in their airbox...would this not be better? it would be increased airflow, obviously, but im guessing that since nobody seems to be using it, there must be something wrong with it... anyways...im new at this stuff, and my 2.7 is slow, so let me know. haha! thanks!
Old 07-08-2004, 01:27 PM
Plays_with_Toys's Avatar
I thought you were posting it to sell it, and I was thinking to myself, go away troll, this isn't an advertising forum
Anyhow, I believe the consensus is airbox modification is cheaper, and by doing the deckplate mod, you can cap it to make sure water doesn't get in. Most cold air intakes take air right by the front tire, which makes the intake very low. If you do even small water crossings, you run the risk of sucking in water.
Old 07-08-2004, 01:35 PM
jimbo74's Avatar
they are fine if going the srteeter route... however, that kit just is explained poorly and appears to not really have any thought in it... i would rather get one from a company that at least can BS me into thinking they are reputable....
Old 07-08-2004, 01:43 PM
rimpainter.com's Avatar
I totally agree with jim.
Old 07-08-2004, 01:57 PM
Dan_90SR5's Avatar
I'm honestly confused on what to do about an intake at this point. I have always thought K&N was the way to go, then I read on Gadget's site about an intake made for the Taco or 4Runner (which would be the same) that actually lost hp when dyno tested.
He is using a modified airbox with an Amsoil filter now and gained hp. I wanted to take my airbox out, but Amsoil doesn't make a cone type filter. I guess I/we'll have to either come up with a better idea or suffer with the current options.
Old 07-08-2004, 02:17 PM
Dan -
Another option is to just get the K&N and add the optional "jacket" when you go off-roading. I hear the K&N cone filter system helps on the 3.0.
Old 07-08-2004, 02:49 PM
Mohamed's Avatar
No no, avoid the K&N...guys seriously look at the Trueflow air filters. much the same thing as an amsoil but they make an intake that uses alot of the stock components. From what i have been reading, it's probably THE BEST, yes I said it, the best aftermarket air filter, still nothing beats OEM, and that's why I am not putting it in my Tundra. If you really desire to put a drop in or an CAI intake charger, the trueflow seems like a really excellent product and better choice. If they made one for my year Honda, I would install one in. www.trueflow.com
Old 07-08-2004, 03:10 PM
Mohamed-
They only make them for the 3.4L that I can see.
Old 07-08-2004, 04:41 PM
Mohamed's Avatar
Originally Posted by <96 Runner>
Mohamed-
That you're right, but for a drop-in air filter, they do make one for the 2.7 4 cylinder, and I know the question is for a CAI, but for this instance, I really would shy away from the K&N, Airraid, and any of the other cone filters out there. This drop-in will at the very least, give you better throttle response.
Old 02-08-2006, 08:00 PM
Runner003's Avatar
I had a 90 Toy PU with the 3.0. I put in a "drop-in" K&N filter the gas milage was awesome then I did a cat back system free flow Cat and muffler. I was able to bark the truck in second.. Sometimes I wish i still had it over my 99 3.4 4Runner... But Family first... But for the 4Runners the MAF is to sketchy with the oil on them.. .
calderp
Engine Swaps
08-16-2016 05:15 PM
Swim
9
01-04-2016 10:47 AM
4runnerstalls
08-26-2015 11:13 PM
rjtrials
08-06-2015 07:25 PM
calderp
07-27-2015 09:58 AM
Quick Reply: Cold air intake...
