# of Coils in Stock 96 Taco front springs??
Old 11-16-2009, 11:39 AM
LanceN's Avatar
I just replaced my old Rancho's with some new Billy 5100's. I didn't have a strong enough spring compressor at home to compress the coils so I took them to a shop and had the shop swap over the shocks after I took the strut out of the truck. Yesterday I was taking the 3" block out of the rear leafs and replacing it with a 1.5" block and noticed my truck was sitting high on the passengers side. I double checked that i had the 5100's set on the same perch and they were. So then I counted the coils on my springs.....driver side had 8 or 9, passenger side had 11...WTF???
I bought a better spring compressor and dropped the passenger lower spring perch so now my front is level, cheap quick fix until I can get new springs.
But, can someone tell me which is correct.....9 or 11?
Thanks!
Old 11-16-2009, 11:51 AM
TOYOTA 1's Avatar
both sides of mine have 10.
though it is a 2000, i don't know if that matters or not.
Old 11-17-2009, 10:47 AM
eddieleephd's Avatar
I would put it back and swap the struts on the front the battery is heavier and it needs more support as well the fuel tank needs more so then I would adjust the rear
where are you I have a pair of stock 99 struts in the bed of my truck and will part with them pretty easily.
Old 11-17-2009, 10:50 AM
TOYOTA 1's Avatar
hey eddie is that a bong in your avatar lol?
Old 11-17-2009, 11:18 AM
That would be a hell of a bong but no it is a didgereedoo made of bamboo!
one of a couple instruments I do play!!
Old 11-17-2009, 11:21 AM
TOYOTA 1's Avatar
haha i was just messin anyway.. i just watched a tube vid, things sound pretty cool.
Old 11-17-2009, 11:52 AM
habanero's Avatar
My 96 4runner had 10 blue/blue on the driver and 9 blue/yellow on the passenger.
Old 11-18-2009, 08:10 AM
LanceN's Avatar
Thanks Eddie,
Even though I don't want to admit it, because I don't want to swap these struts again , I agree with you to a degree. The fuel tank adding extra weight to the drivers side yes, but it seems most of that should be absorbed by the rear leafs. A 40 pound battery in no way warrents two extra coil springs in a 2 ton truck, I just can't buy that one. However, all things being equal and trusting the shop didn't accidentally install a wrong spring, my truck was level before I swapped shocks. I'll swap them again soon enough simply because things like this drive me nutz, and I'm ready to drive my friggin truck!!!!
BTW - Did you live in Marietta?, I used to live in North Georgia for a while, grew up in the SW corner of Ga.
Thanks,
Lance
Flying91
45
04-11-2024 04:39 PM
lledwod
08-30-2016 01:03 PM
88sasturbotoy
08-11-2015 01:56 AM
Nickdigg
07-07-2015 06:04 AM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: # of Coils in Stock 96 Taco front springs??
