coilover adjustment
coilover adjustment
am assuming it isn't very hard-but i have never done it before. i have the fabtech set up and would like to increase the driver side height alittle bit to even out the front end- can anybody walk me throught it/ thanks. rob
I don`t have the Fabtech setup but you would need to remove the wheel, loosen the adjusting collar bolt, and use a spanner wrench and tighten the collar. I would use half turn increments and check ride height. Adjusting is the toughest part because you have to remove/replace wheel then measure until you get it where you want. Also, I suggest driving it to allow it to settle before finalizing the height you want. Hope this helps.
Mr. iNCREDIBLE
02-20-2013 04:24 PM
