Coil Spacers bad on CV joints?
Old 02-20-2008, 08:00 PM
NwRunner's Avatar
Ive heard that coil spacers are bad on your CV joints. My buddy said that his were throwing grease everywhere when he put 3inch spacers in. Just seeing if this is something to expect with doing spacers rather than the whole shock/spring system.
Old 02-20-2008, 08:23 PM
toytech76's Avatar
whether you do coil spacers or shocks and springs, you are getting the same result of steeper cv angles. Its not bad to do, just get a 1" diff drop with it and you should be ok. If you have a few extra $, you can buy a tacoma 4" front end kit and lc coils for the rear and not worry about cv angles
Old 02-20-2008, 08:46 PM
tacoma728's Avatar
no they are perfectly fine for everything.
Old 02-20-2008, 08:47 PM
tacoma728's Avatar
i like this thread.
Old 02-20-2008, 08:50 PM
NwRunner's Avatar
dont mock my lack of knowledge, haha
Old 02-20-2008, 09:55 PM
stormin94's Avatar
They are blown, get some new ones, and diff drop.
Old 02-21-2008, 01:06 AM
Jdizzydub's Avatar
3rd gens are plus 10years old. and cranking the cvs at angles they haven't been in would make them cranky. sounds like they are blown or it could've been a torn boot to begin with. but IMHO it's the nature of the beast when modifying the suspension. x2 on the diff drop to relieve cv angles.
Old 02-21-2008, 02:34 AM
Bighead's Avatar
Just because the boots are leaking grease does not mean the CVs are blown...just that you are leaking grease. If you don't fix the leak then that eventually could lead to your CVs wearing prematurely.
Old 02-21-2008, 06:12 PM
ROOFGOOF's Avatar
It appears that the coil spacers that are over 2.5 inches tend to make the CV's puke. Most guys are safe with 2.5 inch spacers with the diff drop. I never had problems with the cornfed 2.5 inchers.....but I've seen a decent amount of posts with problems with the 3 inchers.
Old 02-22-2008, 03:12 AM
MTL_4runner's Avatar
X2
Even a mild lift can cause the boots to leak on a 10 year old vehicle.
sandyota
02-04-2021 11:16 AM
09-04-2015 09:27 AM
coffey50
07-28-2015 10:55 AM
terminator
07-27-2015 07:13 PM
ksmudrunner99
07-21-2015 05:33 AM
Quick Reply: Coil Spacers bad on CV joints?
